Kick Timing Belt vs GV Oil Change - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2004, 02:24 PM   #1 (permalink)
Bobzooki's Avatar
Member # 9419
OK, so yesterday's tasks:
  • Replace the timing belt and tensioner on my 95 4-door Kick.
  • Change the oil in my wife's 1999 Grand Vitara
Guess which one was a bigger pain in the ass?
To keep from having to drain the radiator on the Kick, it was a challenge to get the fan shroud off - but disconnecting th PS fluid reservoir from the side of the radiator made it pretty easy. You can't even SEE the 5 mounting bolts on the crankshaft pulley. The 4 mounting nuts for the fan, on the water pump, are pretty hard to get my fat hands on 'em.
But for crying out loud, I had to disconnect the steering linkage to get the damned oil filter off the GV, and then, of course, you can't even get the filter off the engine without losing most of the oil in it, down the side of the engine, and all over the cross member.
I'd rather do another timing belt swap, than another oil change on that damned GV!!!
2012 Tahoe 24' Fish-N-Fun Tritoon, w/115hp Merc
Tow Rig: The Battlestar Galactica
Bobzooki is offline   Reply With Quote
Old 02-09-2004, 02:36 PM   #2 (permalink)
Member # 8687
Next time poke a hole in the oil filter and let the oil drain into a container before you take it off.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 02-09-2004, 02:45 PM   #3 (permalink)
Bobzooki's Avatar
Member # 9419
That would probably make it easier to get the beast off, too!
Old 02-09-2004, 09:38 PM   #4 (permalink)
Member # 19890
Re: Kick Timing Belt vs GV Oil Change
Wow...takes me 10 minutes. You must have fat hands!
[FONT=Tahoma]'83 SJ410, '00 Grand Vitara[/FONT]
Tim J is offline   Reply With Quote
Old 02-09-2004, 09:53 PM   #5 (permalink)
Member # 22191
Send a message via MSN to Crab Bait
You have been watching the PRO-BOWL to take so long!
Zuki Owners; Engineering Innovation not Repetitious "Tuesday" Imitators
Crab Bait is offline   Reply With Quote
