Member # 16773
Lucky 13 questions
I'm lookin' at runnin' the sidekick tranny/t-case behind the 1.3 in the zuk. I searched but the seach won't take 13. So for the next guy Lucky Thirteen. Aight, questions, what clutch do I need? Can I up grade to the larger flywheel and clutch off the 1.6? Are the pilot bearings the same? Is the 1.6 tranny still a cable actuated clutch? Thanks for any help on this
To many damn projects!!! |
#3 (permalink) | |
Member # 908
Use the 1.6 pilot. Yes, the 1.6 is cable actuated.
I take my zuk out for walks. |
#5 (permalink) | |
Member # 908
You will also need a 1.6 starter.
#6 (permalink) | |
Member # 8111
Your other option is the RingR which adpts the 1.6 Bell to a Toy trans. like this
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 Last edited by Rockrat; 04-20-2004 at 12:59 PM. |
Member # 16773
That is actually what I am lookin' at for a later date, but at this time my buddy has got a sidekick tranny/t-case that I can get for perty much nothin'.
figured I could throw that in front of the sammi case for now, see how long it takes to demolish the sammi case. Then I'll go lookin for toy cases!
Member # 21766
Do the 1.6 5-speed tranny and the 1.6 auto 3-speed tranny have the same bolt pattern at the engine? I'd like to use the Lucky 13 to mate the auto behind the 1.3L if this is possible.
Member # 4862
I ran the Lucky 13/Ringer combo for a while nice product, however it left me want more motor. I had the gears to go with the tires, but that was it, the 1.3L just didn't cut it for me.
[url]http://www.myspace.com/jerrywsparks[/url] |
#10 (permalink) | |
Member # 9869
#11 (permalink) | |
Member # 21766
- one 1.3L engine. - one auto 3-speed 4x4 tranny from a Track-Kick. - one stock Track-Kick transfercase (which I'll likely send to OTT for the Kicker3 set-up). - one stock Samurai transfercase still in place in the LWB. Good 1.6Ls are hard to find here and everyone wants a mint even for a rusted-out POS Track-Kick. Seems since the Lucky 13 is so cheap it would be the logical choice right now. Later on I'll swap out to a 16-valve if I can find one and be done with it. So, will I be able to use the auto with the Lucky 13???
#12 (permalink) |
Member # 8111
Yes you should be able too same bolt pattern as the standard trans
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#13 (permalink) |
Member # 21766
Thank you Scott. You are a man of great knowledge and integrity.
Trail rig: Propane-powered Jeep CJ buggy w/454, TH400, Atlas, linked front and rear-steer Rockwells, 49" Iroks on 20" beadlocks. Street truck: 1970 5-ton M818 6x6 on 53" XZLs |
#14 (permalink) | |
Member # 7742
#15 (permalink) |
Member # 8111
I will check into that interesting to know
#17 (permalink) | |
Member # 4862
Thats pretty much where it lead me, however the lucky gave me option between the 2 of them until I had more money to do the motor.
#18 (permalink) | |
Member # 21766
#19 (permalink) |
Member # 15705
OK, forgive me here, I'm ultra nOOb when it comes to Zuks.
I have the my tin-top behind the shop and the 1992 Tracker with a 1.6 on the trailler...I haven't even looked at the things yet. I am planning on using the 1.6 in the Zuk. The Zuk came with a new-in-the-box clutch for the 1.3. It's sitting on the driver's seat. I'm assuming that this will NOT work with the 1.6. Correct? Thanks for the help. RJ
[b]In the mornin you go gunnin' For the man who stole your water [/b] |
#20 (permalink) |
Member # 7742
no, it wont work just sitting on the drivers seat, you need to install it. Yes it will work (along with the sami flywheel) if you install the 1.6 in the sami with the samis transmission.
#22 (permalink) | |
Member # 15705
Damn...how about if I put it on the hood? Cool glad it will work. Thanks! what's the going rate for a Tracker auto with 100k+ on it? I have one in NH/ME
[b]In the mornin you go gunnin' For the man who stole your water [/b] Last edited by Bertha the Cruiser; 04-23-2004 at 05:39 AM. |
#23 (permalink) | |
Member # 8111
