Turd samurai build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2016, 12:32 PM   #1 (permalink)
Member # 562866
Turd samurai build
So, this is my first offroad rig.
Started building it in February. I have enough progress to start a build thread now, I guess.
Here is what I started with:
I got a rusty frame and a beat body for free from a friend. The frame had big rust holes behind all the bumpstop mounts.
I used a 4 door geo tracker as my engine donor:
While I was gathering parts I wheeled the tracker for a bit on 31s
And then the b pillar separated from the floor so I retired it and tore the engine out.
And started the build on the samurai.
So I bought and trussed a front axle
And patched the frame up, and made my own yj spring kit.
Picked up a parts car
And then stripped it for the parts I needed.
#durangoclan
Alex456123 is offline   Reply With Quote Quick reply to this message
Old 12-01-2016, 12:33 PM   #2 (permalink)
Member # 562866
Then I painted the frame, dropped the engine and transmission in, and put the axles under it.
Then there is a big skip in the timeline because my phone screwed up and I lost some pictures.
But in that time I had gotten the body on and got it running and driving.
#durangoclan
Old 12-01-2016, 12:38 PM   #3 (permalink)
Member # 562866
Next things to do on the list is to find a set of 5 leaf springs for the rear, as the 6 leaf packs are way too stiff. I have to make a cage and install the locker in the front, and weld the rear, and weld in rear shock mounts.
Then just wheel it.
#durangoclan
Old 12-01-2016, 02:41 PM   #4 (permalink)
ScottieJ's Avatar
Member # 140900
Looks good.
Why don't you just pull a leaf from each rear spring pack....there's your 5 leaf pack
Steady as she goes
ScottieJ is offline   Reply With Quote Quick reply to this message
Old 12-01-2016, 05:35 PM   #5 (permalink)
Member # 562866
Originally Posted by ScottieJ View Post
Looks good.
They are nice aftermarket hd springs that have less arch than normal yj springs. I don't feel like cutting these up anyway. Lol
#durangoclan
Old 12-01-2016, 10:02 PM   #6 (permalink)
nbk9nbk's Avatar
Member # 230672
Not sure what you budget is but I but i bought a new mini spool for 65 shipped from rms looks like it may be better than welded
Sent from my SM-G930T using Tapatalk
nbk9nbk is offline   Reply With Quote Quick reply to this message
Old 12-02-2016, 11:30 AM   #7 (permalink)
Member # 562866
I am welding in between the teeth of the gears, not welding the gears together or welding to the carrier. That way it will be removable.
I'm on a shoe string budget. I have a total of 1000 into it including materials so far.
#durangoclan
Old 12-02-2016, 11:43 AM   #8 (permalink)
nbk9nbk's Avatar
Member # 230672
I have more than that in my front shocks lol congrats on the 1000 mark so far.... the 65 for the mini spool was worth it for me to have no heat to weaken gears and have it removable espically with having to take it all apart anyways...the gears are so tiny and weak looking when you get in there... I read alot of reviews some said the fuzzy locker style like your doing worked for a few most reviews didn't and when it breaks it destroys everything in there. I hope yours holds up tho..
Old 12-02-2016, 11:47 AM   #9 (permalink)
Member # 562866
I have more than that in my front shocks lol congrats on the 1000 mark so far.... the 65 for the mini spool was worth it for me to have no heat to weaken gears and have it removable espically with having to take it all apart anyways...the gears are so tiny and weak looking when you get in there... I read alot of reviews some said the fuzzy locker style like your doing held up most reviews didn't. I hope yours holds up..
If it doesn't hold up, not much will be lost. I have a few spare 3rd members that I can throw a spool in if needed.
These axles won't be permanent either way. I am going to build front and rear tracker hybrid axles and link the front when I get the cash
#durangoclan
Old 12-02-2016, 09:12 PM   #10 (permalink)
melbakid's Avatar
Member # 719362
Question
Will you be doing a write up on the tracker hybrid axle buildup?
I have a 95 Sidekick parts car and was thinking of doing this.
melbakid is offline   Reply With Quote Quick reply to this message
Old 12-02-2016, 10:48 PM   #11 (permalink)
Member # 562866
I could probably do that. I don't imagine it will be very hard. The worst part will be keeping it straight while welding.
I think there is already some detailed write ups on it though.
#durangoclan
Old 12-03-2016, 07:10 AM   #12 (permalink)
Member # 9033
Holly rust belt problems, Batman!
UA 2013 participant
Thank you: Nitto Tires, Polyperformance, Nitro Gear and Axle, Bubba Rope.
MudKick is offline   Reply With Quote Quick reply to this message
Old 12-03-2016, 01:39 PM   #13 (permalink)
Member # 562866
At least the floors on the tub I am using are pretty solid.
#durangoclan
Old 01-08-2017, 10:10 AM   #14 (permalink)
Member # 562866
Made a truss for the rear axle and boogered it on...
#durangoclan
Old 04-20-2017, 07:18 PM   #15 (permalink)
Member # 562866
So I've had it out a few times now, works pretty good.
To prep it for this weekend I made a little wood platform to hold my cooler above the gas tank, and added rear shocks.
Night and day difference having the shocks on there. Lol.
#durangoclan
Old 04-21-2017, 07:29 AM   #16 (permalink)
nbk9nbk's Avatar
Member # 230672
Update on the mini spool passengers side teeth in the spool stripped in the first 24 hrs...trying a yukon brand spool next
Old 04-21-2017, 10:25 AM   #17 (permalink)
Member # 562866
That's what I was afraid of lol. My welded dif Is still holding up so far with some mild rock crawling.
#durangoclan
Old 04-24-2017, 11:53 AM   #18 (permalink)
Member # 562866
So my trip out to RBOR at r&v Saturday was a ton of fun.
I made it up the new reorganized big ugly, and made it up the rock wall obstacle in the gravel pit.
And I sunk it.
#durangoclan
Old 05-02-2017, 09:44 AM   #19 (permalink)
Member # 554834
Very cool to see a budget build, I just got my first samurai last month but haven't gone out with it yet. What will the ratio be with the hybrid axles?
Flyingwigs is offline   Reply With Quote Quick reply to this message
Old 05-02-2017, 08:04 PM   #20 (permalink)
Member # 562866
Yeah I love the budget aspect of it, I currently have $1190 into it. Hope to be around 2k-2500 when it is completely done, caged, linked, chromos, regeared and probably on 33s.
The hybrid axles will be 4.80 2nd gen Vitara rear gears. I might just build a hybrid rear, I don't really see a need to loose diff clearance in the front when I don't need the extra strength.
#durangoclan
Old 05-03-2017, 03:52 PM   #21 (permalink)
Suzuki/Toyota Parts
Low Range's Avatar
Member # 80948
Very cool! Looks like you were having a blast and kicking butt and taking names until you sunk it lol! Change your Gear oil so the water doesn't take your bearings out in your t case and Differentials.
As for minispool.. I prefer welded .
Order online at
Check us out on Facebook
Follow us on instagram:
#lowrangeoffroad @Lowrangeoffroad
YOUR Suzuki and Toyota Parts SUPER SHOP. Over 7800 Products and Counting.
We ship WORLDWIDE.
Why buy from Low Range Off Road?
We keep records of sales from the day you buy your product. Need a product warranty? Lost your receipt? Yep, we have it.
Low Range is offline   Reply With Quote Quick reply to this message
Old 05-04-2017, 09:05 AM   #22 (permalink)
Member # 562866
I checked my fluid. No water intrusion. I have long breather tubes on the axles.
Now I need to find a spring and pin kit for this lockright locker.
#durangoclan
Old 06-10-2017, 09:51 PM   #23 (permalink)
Member # 562866
Jumped it. Cracked the jb weld off the oil pan, so I had to fix that. Lol
#durangoclan
