Push Button Starter - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-22-2004, 06:24 PM   #1 (permalink)
Member # 28004
Send a message via Yahoo to gris0911
Push Button Starter
B4 you all flame me I tried the search and only found the ways to bypass everything to install my switch.
My question is who is running a push button starter that is hooked up so you have to have the key in the ignition and turned to the ACC then push the hidden start button?
Which 2 of the 4 wires do I need to cut off the back of the ignition switch and hook up to my button??
I read the thread that was started by NC_Zuk but it didn't say what wires need to be cut and spliced into the button.
Thx in advance to all that will help
'88 Zuk
8" Frame Extension S/R on YJ's, Yota IFS steering, 33's, 5.38's, 1.6l 16v, 4.16 T/C. http://www.poosnack.com/projects/zuk.html
gris0911 is offline   Reply With Quote
Old 04-22-2004, 06:32 PM   #2 (permalink)
Member # 8687
I think the wires are labelled on the back of the switch if I remember correctly. You want the one that's labelled STA.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 04-22-2004, 07:16 PM   #3 (permalink)
Member # 28004
Thx
I just got it done, works fine. I should have went outside and tried it b4 I asked. If any one is ever wanting to do this simply cut the black/yellow wire behind the ignition switch and run it to one of the terminals on the push button starter switch. Then splice into the white/black wire on back of the ignition switch and run it to the other terminal on your button. Done in this way you have to have the key in the ignition and turned on before the button will work.
'88 Zuk
Old 04-23-2004, 07:53 PM   #4 (permalink)
tanzuki's Avatar
Member # 15771
Send a message via ICQ to tanzuki Send a message via AIM to tanzuki Send a message via Yahoo to tanzuki
With a test light it is not that hard to figure out. You also may want to consider what I did. I just spliced into the wires so i can start it with the switch or the button. The reason I did it this way is because my ignition doesn't hold my key in so when I'm hill climbing and I start to bounce sometimes my key falls out, so now I just turn the ingition on and put the key in my pocket.
YO YO HA!!!
tanzuki is offline   Reply With Quote
Old 04-23-2004, 11:55 PM   #5 (permalink)
Banned
Member # 2540
Location: Meadow Vista, CA and University Place, WA...moving soon
Send a message via Yahoo to Storm Trooper
the wire colors change with the years
Storm Trooper is offline   Reply With Quote
Old 04-23-2004, 11:57 PM   #6 (permalink)
Banned
Member # 2540
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white/yellow |+ |ignition harness |
| STARTER|black/red |+ |ignition harness |
| IGNITION|black/blue |+ |ignition harness |
| SECOND IGNITION| | | |
| ACCESSORY|blue |+ |ignition harness |
| POWER LOCK| | | |
| POWER UNLOCK| | | |
| PARKING LIGHTS +|red/black | |steering column |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|red/white |+ |steering column |
| DOOR TRIGGER|black |- |at pin switch*2 |
| TRUNK/HATCH PIN| | | |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|brn/wht or brown | |at coil or ECM*1 |
| BRAKE WIRE|green/white |+ |at brake switch |
| HORN TRIGGER|blue/green |- |at column |
| WIPERS| | | |
| LF WINDOW UP/DN| | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
Notes:
*1 ECM located on right side of dash behind glove box. *2 Only drivers door has pin switch. Add pins for passenger door and rear gate.
I have techsoft on my home PC if you guys ever need specific stuff for vehicles just shoot a PM my way
Old 04-24-2004, 12:48 AM   #7 (permalink)
Member # 5832
hey that's cool ST
UZI 9mm is offline   Reply With Quote
Old 04-24-2004, 11:59 AM   #8 (permalink)
Banned
Member # 2540
its for doing alarms and stuff, makes things way quicker
