YJ spring/Frame extension How to - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2004, 08:47 PM   #1 (permalink)
Member # 27453
Send a message via AIM to XJOSHX
Has anyone ever done a step by step article on how to do a YJ swap and frame extensions? Maybe a build up thread that had sooo much detail it could be used as a how to? I have been searching and have not found anything. I have found questions with answers but not a full how to.How hard would it be to get a 90-95"WB out of a set up like this? Thanks
XJOSHX
XJOSHX is offline   Reply With Quote Quick reply to this message
Old 04-23-2004, 09:07 PM   #2 (permalink)
CanyonSamurai's Avatar
Member # 28494
I am doing the same thing right now. I am going about 5 1/2 inches longer on the frame with 2/4, 1/4 inch thick metal. And fish plating both sides.I am putting shackles up front and running Cj springs. I will be right at 92". The front will be cut amd a tube clip built the tires will rub. I dont really know how to step b step it.
CanyonSamurai is offline   Reply With Quote Quick reply to this message
Old 04-23-2004, 09:24 PM   #3 (permalink)
Member # 27453
Do you have any pictures? I know I am going to have to do this pretty soon and i am not 100% sure how. I know I can trial and error and get it done rpetty easy, but I would rather get it done first shot.
XJOSHX
Old 04-23-2004, 09:38 PM   #4 (permalink)
Member # 8690
Send a message via AIM to jp008 Send a message via MSN to jp008
Right here.
It's not step by step but it should work for ya.
Jim Phillips (D.O.R.)
87 Samurai-91 Kick
jp008 is offline   Reply With Quote Quick reply to this message
Old 04-23-2004, 10:08 PM   #5 (permalink)
Member # 27453
Oh ya, I forgot to ask, will stock yj springs give enough lift for 35's? I will probably have a tube front clip and flat fender the rear.
XJOSHX
Old 04-23-2004, 10:27 PM   #6 (permalink)
Member # 2752
Here is the article scwafish did on ORC http://www.off-road.com/suzuki/featu...a/samyota1.htm
It is tough to get more than around 87-inches out of the YJ setup unless you want to extend your frame a LONGGGG way in the front or get rid of the gas tank in the rear. An 8-inch extension in the front and setting the rear back as far as you can clear 35's pretty well and gets me to the 87-inch mark.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote Quick reply to this message
Old 04-24-2004, 08:52 PM   #7 (permalink)
Member # 977
Allusee had a thread with all of the dimensions discussed a while back.
eXtreme web-wheeler!
scwafish is offline   Reply With Quote Quick reply to this message
Old 04-24-2004, 10:37 PM   #8 (permalink)
Member # 7418
Send a message via ICQ to Arizona Zuk
http://groups.msn.com/badazxj/needbiggerramp.msnw
check out Frank's junk on the ramp with s/r yj's and foxshox in the back....it's got 37" MTR's on it....
BTW Chris V has some great info on his site about s/r yj's too....I think he has pix on how to set it up.....
Dave
Arizona Zuk is offline   Reply With Quote Quick reply to this message
Old 04-25-2004, 03:24 PM   #9 (permalink)
Member # 27453
I searched around, all I found were pics of boobs and what not. Do you rememeber the name of the thread by any chance?
XJOSHX
Old 04-26-2004, 04:18 PM   #10 (permalink)
Member # 27453
Also, I have someone that is willing to give me a set of 2" lift YJ springs with a military wrap. Will those work on a samurai?
XJOSHX
Old 05-05-2004, 12:34 PM   #11 (permalink)
Member # 27453
I have a spare samurai chasis to chop up to make extensions. Would this be better than the regular 2x4 boxed steel?
XJOSHX
