Member # 5424
max pinion angles
HEY GUYS,
I just finished a custom yj springs fron and back with a shackles reversal in the front. I am getting some vibrations in the rear and when I droop the front the driveshaft hits the t-case crossmember. I am thinking of raising the pinion angles up(with shims). Anyone know what the maximum angles can be in the front and the back? Thanks Chubbs
Keep on a Wheellin' |
Member # 8111
deg
I run the wranglers in the rear with 4 deg shims the font same but I cut pads off rotated the axle. Fab a bracket to go over your driveshaft that way it dont get inthe way under full droop
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
Member # 5702
For the front driveshaft hitting the crossmember, add a spacer between the t-case and front shaft. I used a 1 inch spacer from Spidertrax on mine. Angle seems fine, too. ~Steve
[url]www.colorado4x4.org[/url] |
