Axle Wrap Issues - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-29-2004, 07:04 PM   #1 (permalink)
earnie's Avatar
Member # 29477
Send a message via MSN to earnie
Axle Wrap Issues
I am wondering how many people are running some sort of anti-wrap device. Particularly those who have very low gears and are running Jeep YJ wrangler leafsprings. ALso if those people could post pictures of ones that they have made, particularly for toyota axles.
earnie is offline   Reply With Quote
Old 06-30-2004, 12:58 AM   #2 (permalink)
Member # 8690
Send a message via AIM to jp008 Send a message via MSN to jp008
I run XJ springs backwards on D44's and I have a ladder bar type setup with a shackle up front that works great.
Jim Phillips (D.O.R.)
87 Samurai-91 Kick
jp008 is offline   Reply With Quote
Old 06-30-2004, 05:41 AM   #3 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
One's like jp008 posted are the only ones I have seen that work well.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 06-30-2004, 07:07 AM   #4 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
are you running bushings in all four mounts? how does it twist when the axle flexes?
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and fox coilovers, 8.1 liter 496 bbc/4l80e/BWtcase. DD/towrig
jays68yak is offline   Reply With Quote
Old 06-30-2004, 11:09 AM   #5 (permalink)
Member # 8690
running bushings in the rear and a heim up front. I will be changing the bushing to johnny joints shortly. It doesn't flex as well as I had hoped for with the bushings. without the bar it almost flexes too much.
87 Samurai-91 Kick
Old 06-30-2004, 05:57 PM   #6 (permalink)
Member # 15708
Send a message via Yahoo to GA_ZUKI
well here are some pics of the trac bar from grumpy.
i tested it on the ramp. it allowed me to go further up the ramp
i'm still at 15 psi i run 5 on the trails on bias ply tires
i still have no shocks it was stiffer than with out
GA_ZUKI is offline   Reply With Quote
