yes this is a stupid question. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2004, 01:56 PM   #1 (permalink)
Member # 22513
Well...the sami is cut well into alot of pieces,so its not moving. i need to know which way the drive shaft spins going into the front and rear axle. IE clockwise/counterclockwise looking from the t case down to the axle. Im going to run waggy 44s, butt...i have a hp ford axle housing that ill be puting the tubes into. so i just need to check and make sure eveything is going the correct direction. yah i know its stupid
CJ-8,heavily modified?
HOOLIGAN ROCK CREW.
CRICKET is offline   Reply With Quote
Old 07-21-2004, 02:12 PM   #2 (permalink)
Member # 9033
The reverse spiral diff (aka: high pinion) spins the same direction as the standard diff, so you'll have no problem with using it.
My build: [url]http://www.pirate4x4.com/forum/suzuki/1022756-sidekick-tracker-pickup.html[/url]
MudKick is offline   Reply With Quote
Old 07-22-2004, 09:08 AM   #3 (permalink)
Member # 29991
I 'spose you could jack up one wheel and turn the driveshaft by hand. Watch the wheel turn. Unless you have lockers, then jack up both rear wheels.
GeoB is offline   Reply With Quote
Old 07-22-2004, 01:59 PM   #4 (permalink)
Member # 22513
yah i know but i was looking to make the call yesterday on the housing, couldnt get to the sami axle until this weekend. thanks for the info seems like it should be fun.
HOOLIGAN ROCK CREW.
