Cracks at seat attachment points... what to do? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2004, 04:12 PM   #1 (permalink)
Member # 33189
Ok, so cleaning out the zuk I discovered that almost all of the mounting positions on the floorboard are cracked. The metal around the bolt holes literally has one or more inch long cracks extending from the holes. What did you all do 'bout that... I'm assuming it's a common thing.
I'm guessing I'll just tack down some 1/4 inch square plates as a bandaid... is that ok to do?
Super J is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 05:19 PM   #2 (permalink)
Member # 15343
yep it common mostly on the passanger side.....I just rewelded thew crack to stop any rust then welded a 1/4 plate and drilled a new hole for a nut and bolt.......
then I tell anyone over 250pounds to go ride in the heeps
DIRT, MUD, ROCKS WHATEVER!!!!
Islandzuki is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 06:08 PM   #3 (permalink)
billjohn's Avatar
Member # 6668
Yup... weld it then plate it. Common problem.
Bill Johnston
www.izook.com
billjohn is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 06:42 PM   #4 (permalink)
Member # 8687
Mine did it too.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 07:28 PM   #5 (permalink)
Member # 8267
Mine did it two. I solved the problem by reducing the stress on the seat mounting points (i.e. running on the treadmill and losing weight).
88.5 JX, YJ's, Dana 44's frt & rear, 1.6L 8valve, 33" MTR's, ARB Bull Bar. First Gen K5 350/350
juicebox is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 07:58 PM   #6 (permalink)
TX_Zuki's Avatar
Member # 18577
Mine is attached to the exo cage that is attached to the frame.
TX_Zuki is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 08:09 PM   #7 (permalink)
Member # 5832
Originally Posted by jones
Mine did it too.
LOL this thread is hilarious
I was always too embarassed to mention that my seat base was cracking :fatass:
I had no idea that others had similar....problems
Riveted heavy guage steel sheet metal over top of mine (driver's side raised box section front mount)
UZI 9mm is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 08:43 PM   #8 (permalink)
Member # 15343
Old 07-22-2004, 09:05 PM   #9 (permalink)
Member # 11628
One word of caution to everyone that has filled ther Crack
the plate you use to reinforce the seat, be sure to round all the corners generously, and if its thick plate (1/8" or better) try to take any sharp edges off the sides as well. just chamfer it with a grinder or file.
Reason:
the sharp edges and corners on the reinforcment you welded in WILL tear out the original floor under high loads and flexing of the floor pan.
Just a heads up to all those that dont want thier Cracks growing in the future
BTW....who else burns thru the factory floor when they weld on it?......I dont think my MIG can weld cold enough for that tin foil.
"The road to Enlightenment requires 4-Wheel Drive" - me
Orionn is offline   Reply With Quote Quick reply to this message
Old 07-22-2004, 10:19 PM   #10 (permalink)
Member # 33189
Looks like I'll be fabbing some new mounts at the same time since I picked up some subaru seats =). Thx
Old 07-22-2004, 11:25 PM   #11 (permalink)
Member # 5832
Originally Posted by Orionn
Reason:
yes, very good advice
[Nodding]
*weld, weld*
awe crap, now look what I've done. the hole's bigger than when I started
ended up buying a super cheapo lincoln 110 flux core wire feed, strictly for body and exhaust tubing. My gawd the welds look like bird doodoo, but they don't burn holes through
Old 07-22-2004, 11:49 PM   #12 (permalink)
RocKrawler's Avatar
Member # 416
Have you tried running the thinner .023 or .025 wire? Much easier on thinner metals
Terry - 4 Wheel Parts, Bossier City LA
Soon to be Riverside CA
RocKrawler is offline   Reply With Quote Quick reply to this message
Old 07-23-2004, 04:29 AM   #13 (permalink)
Member # 11628
I am running .023, with 75/25 mix.
The welder is a Miller 185.
perhaps I can change out to pure Argon, that may cool the welds down a bit, but also means I need to buy a new tank I just filled the other one.
