Diodes for flat towing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2004, 07:39 PM   #1 (permalink)
Member # 10649
For those of you that are flat towing...where did you buy your diodes? I looked at towing/wiring kit today at an RV place but they wanted $80 for something that looked like about $20 worth of diodes and wire.
'56 Willys PU - '46 Willys - '08 Tundra
bildo is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 08:06 PM   #2 (permalink)
Member # 33189
Why don't you just get the magnetic ones the tow companies use?
Super J is offline   Reply With Quote Quick reply to this message
Old 10-17-2004, 09:41 PM   #3 (permalink)
Non Urban's Avatar
Member # 21175
I took a pair of trailer lights from Wal-Mart for about $10-$15 and mounted them on to a piece of flat stock welded to a piece of hitch tube that I slip into the receiver of the rear bumper.
[COLOR="Red"][SIZE="4"][B]IF YOU DON'T STAND BEHIND OUR TROOPS,[/B][/SIZE][/COLOR]
[COLOR="White"][SIZE="4"][B]PLEASE, FEEL FREE TO[/B][/SIZE][/COLOR]
[COLOR="Blue"][SIZE="4"][B]STAND IN FRONT OF THEM![/B][/SIZE][/COLOR]
Non Urban is offline   Reply With Quote Quick reply to this message
Old 10-18-2004, 07:38 AM   #4 (permalink)
Member # 10649
I've thought about it but decided against it because I'm trying to limit the amount of stuff I have to carry around.
Old 10-18-2004, 10:19 AM   #5 (permalink)
Member # 25152
I'll check but I know that I only paid $45 CDN for the kit. Includes wiring front to rear, nicely weather-proofed diodes, and the four wire plug. Just called the guy and the price has gone up to $65!!!! but at least you would win on the exchange...HTH
[QUOTE=killr-b]Here is my input--- You sir are a piece of safety equipment worn on the head of an inline skater !!!!!! [/QUOTE]
AnotherCanuck is offline   Reply With Quote Quick reply to this message
Old 10-18-2004, 04:16 PM   #6 (permalink)
MRfuelish's Avatar
Member # 12376
on one of mine I just cut the wires on the stock lights and put in a flat four plug on each side of the cut and ran another flat four wire harness from the front to the rear along the frame with a flat four plug back by the stock tail lights, might cost you a whole ten bucks for everything!
Stock 88 samurai,with 16 valve and 33's
MRfuelish is offline   Reply With Quote Quick reply to this message
Old 10-18-2004, 06:06 PM   #7 (permalink)
Member # 10649
Agreed, but I'm trying to eliminate reverse current flow to the front of the towed vehicle (aka Toad) and (in the unlikely event) reverse current flow from the Toad to the tow vehicle. Hence my question, where did you folks (i.e. those people using diodes) buy your diodes?
Old 10-18-2004, 07:40 PM   #8 (permalink)
Member # 10649
Ok, for those of you that are interested in doing the same thing. Here's what I found with a little surfing.
The diode:
4-wire to 5-wire wiring diagram:
http://www.towingworld.com/Info/fig4.pdf
Source for the diodes:
http://www.roadmaster-tow-bars.com/e...al_diodes.html
And a recap: This system protects the "Toad" and the towing vehicle from current backflow and gives the added benefit of isolating the turn signals to the rear of the Toad while towing. In addition, you don't have to carry or mount separate lights for flat towing. I know this is all very low tech but someone here will benefit from this info (I hope).
Old 10-18-2004, 09:59 PM   #9 (permalink)
MRfuelish's Avatar
Member # 12376
how can you get reverse current flow when you unplug the stock lights from the factory harness(cut and splice in new plugs that wernt there befor) and plug them into your towing harness via your new flat four plugs (two for the stock lights and one for the new towing harness)and a plug for what ever your plugging into your tow rig! to simple, go to radio shack a get a couple of diodes x4 about 10 amps should be way more than you need to do it.
Old 10-19-2004, 05:08 AM   #10 (permalink)
Member # 33313
Send a message via AIM to suprzuk
If anybody is the DIY type and is looking for a good supply for diodes you can try www.allelectronics.com . They are where I get most of my parts when I have an electronic project going on. You can build 3 of those diode boxes for $3 worth of diodes from them. That is using 6amp rated diodes.
Kevin
suprzuk is offline   Reply With Quote Quick reply to this message
Old 10-20-2004, 08:15 PM   #11 (permalink)
Member # 29991
I scored 100' of umbilical cable, like 7-8 conductors, don't recall exactly, at a yard sale for $5. I bought the plug I needed for the Sammi and mounted it in the front, where my tow-bar mounts. I patched into the electrical system in front. It works just fine. I tow with an F250 (with the tow pkg) and i have never had any problems. What reverse current are you worried about? From where? My lights are turned off on the Sammi, but it doesn't hurt anything when I turn em on. Used the setup for years. It is very clean.
I have a bag of big diodes I bought at a yard sale. Over-rated for what I do, and not the most efficient, but they work fine.
GeoB is offline   Reply With Quote Quick reply to this message
