Are these D44? They say Spicer on them.
I got these axles from a neighbor. If they are good, I'm thinking about building them up and putting them under my new Samurai.
I think they are from a Jeep. They have an offset rear. They say 3.54 gears. I have not opened them up yet. They spin and don't look damaged. The front does not have hubs to lock them. They are full time 4 wheel drive. I can almost make out the numbers on them. Spicer 4C-35294 ? 35 C937 16 13 / 3/54 They have a 44 on them. |
Member # 8111
Yes D-44 NOTE IF you want any large gear then a 3:73 you will have to get different carriers.
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#6 (permalink) | |
Should I use these then?
So, now that I know these are D44's, should I use them under my new Samurai? I can get a set of Toyota axles also. I originally wanted to use Toyota axles, but since I have these just sitting here....
How much does it cost to rebuld them? I'm going to spool them most likely. There is no hub on the front, so I'll probably want to convert them to hubs. Locked front would suck driving down the road. My ride has a 1.6TD and Toyota transmission. I'm going to go three link with coils. This is going to be a full on rock crawler but street legal. So is it worth building these up, or should I go with the toyota's.
Meh |
Member # 7272
Are those 5 lug? The only full time 4wd D44 I know of is. 5 on 4.5 or something like that.
87 Zuk,1.6L 16V block w/1.3 8V head,torquer cam,Webber w/modded float bowl vent,RamFlo filter,high flow hogged intake manifold,Holley regulator,6pt DOM cage,SOA,YJ's,DT Prerunners,TT ML's,31" M/TR's,GRS1,Detroit Locker,4.57 RP's,Toy CV Driveshaft,Breeze HighSteer,Bushwacker Flares,Milemarker E9000. |
#11 (permalink) | |
Member # 8111
#13 (permalink) | |
Member # 3301
hey PK-----that last pick...kinda looks like it says "41". edit----not a 41 cause I just checked the cover shape.....I concur on the 44.
http://gearinstalls.com 2001 Taco auto 3.4L stock Last edited by ZUK; 10-30-2004 at 02:35 PM. |
#14 (permalink) | |
Member # 28043
wrong
that's just my .02. good luck |
#16 (permalink) | |
Meh |
#17 (permalink) |
In my experience with swapping in toy axles vs dana 44's. The toys are hell of a lot easier to swap. The toys also have alot more aftermarket axle options than the danas and are much stronger in that aspect. I like the danas because of the open knuckle better turning radius, bigger brakes and stronger housings over all. I have a zuk with danas and one with toys. Which I like better I'm not sure, for the simplicity toys hands down.
87 Suzuki Samurai 4x4, Stock motor, Toy P/S, Transmission, 4:16:1 t-case, Dana 44's f/r. SPOA w/YJ springs. 35" Boggers. |
#18 (permalink) | |
Member # 16978
wrong those are narrow track waggy, quadra track axles, 6 lug . great axles i have a set under mine
Horizon Offroad 405-670-1600 [URL=http://horizonoffroad.com]horizonoffroad.com[/URL] zukzilla-88.5 sammy,2.8 V6,elect emg. brake,D44 4.56 and ARB's,3 link susp. no springs,turn brakes |
#19 (permalink) | |
Member # 16978
get out and look a little ,there is as much for danas as toys
#20 (permalink) |
Member # 22414
Waggy's
DING DING DING. Looks like waggy 44's to me. 6 lug, full-time front, 59" WMS-WMS (I believe). Roomate's rebuilding a set for his heep. 700$ or so for 4.88s with a spool in the rear and master installs. Gonna be another 100$ or so for hubs. I vote for Yota's. Cheaper (and easier) to get lower gears in it. Already come with 4.10's, which would work alright with your setup. Or if you look hard...factory 4.30's or 4.56's. Just my opinion tho.
Allan
93 Toyota beater |
#21 (permalink) | |
Member # 35224
#23 (permalink) | |
I'm also going to probably be bashing them on rocks and what not being a rock crawler and all. So the Dana's would be much better for that. I guess I should also weld on diff caps just in case? I'm going to have to find some prices on rebuilding these. I would like to go disc brakes. I'll need new seals, bearings, and what not since they've been lying in a field for years. I want to spool them, but if lockers are cheap I'll go that way. I want to lock them up on the cheap then save up for Air Lockers. Oh, I'll need to find a steering box for it. I want to go power or hydro assist on them? Since the rear is offset diff, will I have a problem with the Toy transfer case? Is there anything else I need to know?
Meh |
#24 (permalink) |
Member # 10649
Looks like Wagoneer 44s to me. The 3.54 gear ratio is also very common to Wagoneers. The lack of locking hubs is easily corrected. Buy a set of Warn hubs for about $80 and call it done. The Waggys used a drive flange that you'll toss in the trash when you install the Warn hubs. Remove the bearing cover and you'll see the drive flange inside.
'56 Willys PU - '46 Willys - '08 Tundra |
