Member # 37829
Ford 8.8
anyone ever installed a ford 8.8 in their samurai. I know its popular for jeeps. But they are very strong axles. Anyone know of an axle that i could use up front that has the punkin offset to the same side as the samurai axle?
the width of the ford 8.8 is 59" wms-wms |
Member # 11628
Well, unless your getting the 8.8 cheap, you would be better off going with Toyota axles, or Dana 44 wagoneer axles front and rear.
Do some searching and read alot, and then make your decision. Personally I feel the 8.8 is better left for the jHeep guys. Oh, and WELCOME ya Noobe
"The road to Enlightenment requires 4-Wheel Drive" - me |
Hillbilly Houndsman
Member # 13420
It's about the same strength as a D-44.
If you are going to swap one, make sure it has rear disks. That is what would attract me to the 8.8 over other types of axle. Many ford exploders had 8.8 with rear disks. I know it's almost a direct swap into a YJ. So should be super easy for a suzuki. The only downside is that it is a C-clip type axle. Which shouldn't be a problem if you are not running over a 36 or big horsepower.
The penalty for punching someone in the mouth is way too high in our society. www.MountaineerOffroad.com |
Member # 11628
BTW, if ya GOTTA run the 8.8, get a EB D44 front, its about the closest out there for the 8.8 (assuming your getting the 8.8 from an Xploder, like the jHeep guys do)
Or mayby a wide track D30 from a CJ, but you need to check the width. Good luck
"The road to Enlightenment requires 4-Wheel Drive" - me Last edited by Orionn; 11-10-2004 at 11:20 AM. |
Member # 11628
Silverzuk:
your corect, the factory rear disk brakes are about the best thing about the 8.8, and that its marginally stronger that a D44. As for the C-clip 'problem', the jHeep guys up here dont have a problem with it running the big tires, if you get one from a ranger, the spring pads are already SPOA, though they are probably in the wrong place. IMO, unless you have a disk brake model though, I would not run it, just not worth the wieght.
Member # 37829
well the thing is I already have one laying in the back yard.. was gonna put it on my jeep cherokee, but decided to go with the Dana 44 that i bought later on.
Yes i am a noob to the suzuki samurai section but ive been a jeeper for 4 years, so i know my stuff. Just not too educated on the axles you guys like to put in these samurai's. Oh yeah its off a 97 explorer with the disc breaks!!
#7 (permalink) | |
Member # 8284
![]() Other downer would be matching or changing the 5 on 4.5 pattern... |
Member # 37829
And the reason I wanna go with these axles is the extra widt.. this is gonna be a trail only sami. I am used to the width of these axles and have never had a problem fitting into places with the almost 60" wms width. It will give extra stability which i would like to have. Also i am already decent at working on these types of axles "ford 8.8, and Dana axles"
#10 (permalink) | |
Member # 11628
as for the pattern, there is little you can do besides a custom shaft.
