Which Waggy? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2004, 09:27 PM   #1 (permalink)
SOBX2380's Avatar
Member # 23505
Send a message via AIM to SOBX2380 Send a message via MSN to SOBX2380
Which Waggy?
I did the post thing and just couldnt stand sifting thru it all for 2 quick questions. 1- Which year Wagoneer axles are desirable for a swap into a Sammi?
2- I am correct in that they are desirable because the offset closely matches the Sammi...right?
Nick
Tube Frame MiniKrawler
1979 Yamaha XS1100 Motor
Sammi axles
SOBX2380 is offline   Reply With Quote
Old 12-03-2004, 09:54 PM   #2 (permalink)
Member # 7897
Send a message via Yahoo to moto261
here you go /forum/axles-tires-wheels-sale/308104-d44s-zuk.html
I WANNA BE A BUGGY GUY
moto261 is offline   Reply With Quote
Old 12-04-2004, 01:29 AM   #3 (permalink)
Member # 21557
you can use any axle from a 75 to a 79. In 1980 they put the front diff on the left and the rear diff is centered. You might be able to use the early 70's but they do not have disc brakes. The 75-79 years had both diffs offset to the right. samurai axles have both diffs off set to the right. Hope this helps, I used 75 wagoneer 44's under my zuk, great swap!
Brad Juan is offline   Reply With Quote
Old 12-04-2004, 06:57 AM   #4 (permalink)
RgdL's Avatar
Member # 21766
Don't forget to search out older Cherokees too. Same platform and drivetrain as Wagoneers, just 2-door and a little shorter.
And you're looking for those that had the Quadratrac system in them. This was AMC's version of a full-time allwheeldrive transfercase and it had an offset rear output just like the Zuk Tcase. Just keep in mind that not all Waggies and Cherokees had Quadratrac - it was an option. Those that didn't have it have centred rear diffs.
Trail rig: Propane-powered Jeep CJ buggy w/454, TH400, Atlas, linked front and rear-steer Rockwells, 49" Iroks on 20" beadlocks.
Street truck: 1970 5-ton M818 6x6 on 53" XZLs
RgdL is offline   Reply With Quote
