High clearance trans mount? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2004, 12:06 PM   #1 (permalink)
LIKES2CRAWL's Avatar
Member # 25913
Anybody running the high clearance trans mount from Rock 4X Fabrication? Or anybody have pictures of what they did to get rid of drivline clearance issues? I didn't have any problems untill after I did my Toy axles and shackle reversal setup. Any ideas?
[SIZE=3]OLD WISE MAN SAY...."HE WHO GO TO BED WITH ITCHY BUTT.....WAKE UP WITH STINKY FINGER!"[/SIZE] OH YEA... GIT-R-DONE!
LIKES2CRAWL is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 04:13 PM   #2 (permalink)
Member # 8111
I dont know who here has them but there quite a few on the zuwharrie board along with a right up.. I will post some pics after dinner.
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-544.1823
Rockrat is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 04:23 PM   #3 (permalink)
Member # 8111
Heres a review pics coming
Old 12-10-2004, 05:24 PM   #4 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
hey scott I asked is zuwharri but are you able to sell the mount with out any hardware? ( I need all the help with the shipping i can get i'm on an island in AK)
-jay
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
supazuk94 is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 05:39 PM   #5 (permalink)
Member # 8111
P/m'd ya here are some pics on a stocker
Old 12-10-2004, 07:02 PM   #6 (permalink)
Member # 29930
Location: Winchester VA, USA Its America, why should I have to press 1 for English!!
I'm sure it is a proven design and I'm not trying to knock the concept but I'd be worried about slamming the bottom brackets on rocks and moving the tranny out of alignment or bending/breaking bolts.
Its probably just me but I've got a thing about thought bolts to stuff wrapped around the frame. I've ground off more bolt heads on my hardcore 4x4 skid plate that I really hate the concept when you have to drop the skidplate, and have to use vice grips on the bolt heads because you can't fit a wrench on them anymore.
I'd buy this in a minute to save me fab time if there weld on tabs to the outside of the frame instead of the through bolt concept. keeping everything tucked up out of the way.
Just looking at the design a little differently.
TheBanjoman is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 07:22 PM   #7 (permalink)
Member # 8111
Wink
No offence taken But heres the Kicker, the kit was made for a complete 100% bolt in application for the guy that does not have a weder. But if you have a welder the top frame bracket can be welded in place leaving nothing to hang down, AND the x-member is still removable
Old 12-10-2004, 07:57 PM   #8 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
hey scott how far back do you recormend cutting the original xmember? I know you need it to hold the t-case any pics of a rig withthat done? do you have to do any welding?
-jay
-UZI 9mm
thanks to:
Old 12-10-2004, 08:02 PM   #9 (permalink)
Member # 8111
I know Bradzuki cut his out and posted pics I will see if I can find them for you. I do recommend adding a couple tabs to the front where it is cut off by the t-case long arm, it all depends on your gearing and wheeling style I suppose, I know many have done nothing but cut it out and left it.
Old 12-11-2004, 05:14 PM   #10 (permalink)
Member # 25913
I too would like to see pictures with the crossmember cut out. How thick is the mount and what are the odds of it bending?
Old 12-11-2004, 07:03 PM   #11 (permalink)
SPINY's Avatar
Member # 20580
Send a message via AIM to SPINY Send a message via Yahoo to SPINY
I run the mount and it works great I beat on it pretty hard too and havent bent it yet . stock 1.3 4.16 case toy axles and 35" claws redlined and wheel hoppin most of the time haven't even had a bolt come loose yet . I would highly reccomend anything Scott makes his products are top notch.
SPINY is offline   Reply With Quote Quick reply to this message
Old 12-11-2004, 07:34 PM   #12 (permalink)
Member # 17420
[QUOTE I've ground off more bolt heads on my hardcore 4x4 skid plate that I really hate the concept when you have to drop the skidplate, and have to use vice grips on the bolt heads because you can't fit a wrench on them anymore.[/QUOTE]
This may be a solution: When ever I mount anything to the bottom of the frame and/or where a bolt head may be exposed to rocks, etc. I use "carriage bolts". Yes you do need to have a "square" hole to key/lock them in place, but drill the hole and get out the plasma cutter or a file. I have used this method of attaching crossmembers and skid plates for years and have yet to have any problems with removal. A bonus is that they have a round flat head, rather than a hex.makes for a smoother underbelly!
I have some pix to demonstrate............but they are too large and I haven't a clue how to compress. If anybody wants to volunteer I can email them to ya. Any takers?
Hope this is helpful!!
2007 Campbell Buggy w/LS-1,Hughes PG, Atlas 5.0, Hi9- FOR SALE
polkabully is offline   Reply With Quote Quick reply to this message
Old 12-12-2004, 10:45 AM   #13 (permalink)
Member # 8111
The x-member is 3/16" and 3/8" You bend it I will replace it...
Old 12-12-2004, 05:09 PM   #14 (permalink)
Member # 25913
Sounds like I'll be getting ahold of you within the next couple of days to order on then.
Old 12-12-2004, 06:04 PM   #15 (permalink)
Member # 8111
In stock on the shelf ready to ship
Old 12-13-2004, 05:15 AM   #16 (permalink)
Member # 11628
Send them my way, I'll post them for ya.
"The road to Enlightenment requires 4-Wheel Drive" - me
Orionn is offline   Reply With Quote Quick reply to this message
Old 12-13-2004, 07:47 AM   #17 (permalink)
Member # 25913
With the T-case bushings? Or do I still have to wait a week like your site says?
Old 12-13-2004, 10:40 AM   #18 (permalink)
Member # 8111
Yes it takes mea wk for the bushings to come in add $32. or get them from your local zuk dealer
Old 12-13-2004, 07:23 PM   #19 (permalink)
Member # 22073
Here's a couple pics. of the install.
First with the old x-member still there.
Next with the old x-member removed.
Since these pics. were taken I have removed the bolts/mounts from the bottom of the frame & just welded the upper mounts to the frame. The x-member is still removable via bolts to the upper mounts. Anything coming from Scott is top-notch. I've went through 3 t-cases but the tranny mount hasn't budged.
Brad.
Skuzi is offline   Reply With Quote Quick reply to this message
Old 12-16-2004, 04:07 AM   #20 (permalink)
Member # 11628
Pix from Polkabully
Here they are:
Old 12-16-2004, 04:07 AM   #21 (permalink)
Member # 11628
more pix
More pix from Polkabully:
Old 12-16-2004, 04:08 AM   #22 (permalink)
Member # 11628
more pix
Another:
Old 12-16-2004, 04:08 AM   #23 (permalink)
Member # 11628
Last one
Last pic here:
Old 12-16-2004, 04:10 AM   #24 (permalink)
Member # 11628
Sorry for the delay, my subscription expired and it did not auto recycle
Old 12-16-2004, 07:16 AM   #25 (permalink)
Member # 25913
What mount is that for? looks like a Toyota t-case mount.
