Member # 3550
Summer Project
Ok, here's the first look at my plans for the back end of the Zuk this summer. This is my first draft so I don't have all the supports figured out yet. The boxes are storage boxes, anyone got a good source for aluminum boxes w/ locking mechanism? Won't carry a spare unless we are going really far into a trail (like the Con) but I am going to make room for it. Thinking about mounting a pair of the Jeep style tailights which have turn/stop/backup in one unit, they'll be flush with the back next to the spare. Feel free to chime in with any suggestions. Eventually I am going to model the frame/tires so I can get a better idea of the heights. Right now the side bars around the boxes are level with the top of the existing sheet metal.
[URL="http://www.azrockcrawler.com/_images/btgdvd/btgvol4dvd/btgvol4dvd.html"]Built to Grind 4 DVD - 2 Hours of Arizona and NM Rockcrawling [/URL] Chassis Plans for the Do-It-Yourselfer [URL="http://www.azrockcrawler.com"]www.azrockcrawler.com[/URL] BTG Rockcrawlers |
Member # 9193
Allow me to chime in with one suggestion. One item missing from most 4wd cages is the cross support for the main loop. It's often difficult to add due to interference with seating and rear access, but is a very important component. Think about it, maybe early in the process it would give you a chance to design it in cleanly and effectively.
Also, I don't know if you have used it before but, consider 4130 tubing. I've been in the race car world for years, and when I did my exocage I priced chromoly vers DOM and I could actually get chromoly cheaper. It's a little more difficult to work with, but it's amazingly strong. Just because I had some left, I built my lower control arms out of 1-1/2 .100" wall 4130. Everyone (even me) had concerns if it was strong enough. Well, after about 8 months of BASHING them on rocks, they've developed a slight bow but not a single DENT exists! It's also a great way to keep the weight down and still be beast strong! ![]() Looks Sweet. I take it the rear body is going to go the way of the Sawzall
[email]okcrawler@hotmail.com[/email] [url]www.extreme4wheelin.com[/url] [url]www.jffphoto.com[/url] |
#4 (permalink) | |
Member # 5829
Chris, if you are really going to cut the back half of your rig, you'll want to protect those toolboxes more than what you're showing!
Chris check that out he used square tube around the boxes and still has plenty of room in the bed for 1.5 coolers
http://www.imagination-photo.com/pic...l/vernal28.jpg if you want to see a bigger pic let me know I may have some better ones to www.rockmodified.com
Keith Auble - [URL="http://www.rockmodified.com"]www.rockmodified.com[/URL] Life is a Trail - Explore it!! |
#6 (permalink) | |
Member # 5829
(bet I can still put a rock into that latch, tho)
#7 (permalink) | |
Member # 9193
Back from lunch....
Dat's what I'm say'n ![]() I'm thinkin' my next arms will be 1-1/2 1018 BAR STOCK! Low, unsprung weight - good for a rock crawler
#8 (permalink) | |
Member # 3550
#9 (permalink) | |
Member # 3550
#10 (permalink) | |
Member # 3550
#11 (permalink) | |
Member # 5829
Oh I see - your illustration is intended to be used WITH the rear sheetmetal intact (at least some, anyway) I was thinking more along the lines of the blue rig in the photo -- I wanted storage boxes over my rear tires in a bad way, but never figured out a way to do it & have it look like I wanted, so I changed the design. Glad I did, too - you saw what I did to the stake pockets on the r. pass. side!
#13 (permalink) | |
Member # 9193
I don't know how that 3D stuff works.. ![]() We had a (you know what) that rolled end over end and over side recently. His aftermarket cage stayed intact but the center console (with CB etc) ended up directly over the drivers side seat. The problem is, the passenger seat was left completely exposed. Luckily there was no one riding with him, AND it rolled that direction. The cross support keeps the loop from shifting over! As our Sami's get taller and the axles get wider, they tend to land directly on the top corner of the loop.
#15 (permalink) | |
Member # 8284
Happy Friday!
#16 (permalink) |
Member # 8111
dam look kinda like a pepsi can EXPLODED
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#17 (permalink) |
Member # 9458
I agree the cross support is the way to go. It stops the bars shifting and keeps things nice and tight throughout. i have gone a full external cage that is tied into my custom rear tub whih is made out of 2" square as you can see from the progress shots below
[COLOR=Yellow]Nissan GU Patrol, 33" Muddied, Aussie tourer[/COLOR] |
#18 (permalink) | |
Member # 8965
It looks like a Zukish hood.. TLC or some exotic Zuk? -Wayne |
#19 (permalink) |
Member # 9458
It's a Mercedes Benz G Wagen
Absolutley awesome offroad comes stock standard with front and rear lockers checkout more info here http://www.suzuki-4wd-club.rockcrawl.../godfreys.html
#20 (permalink) |
Member # 4862
How are you going to tie the front hoop into the main hoop? You might also want to consider some type of cross support on the down bars off of the main you have in the picture. Also from what I see in the pic, he has a spreader from side to side. It's not as good as a corner to corner but it's better than nothing at all. Looks clean, can you build it? What size tube do you plan on using?
[url]http://www.myspace.com/jerrywsparks[/url] |
#21 (permalink) | |
Member # 3550
I haven't drawn my existing cage yet, but that's the main that's on my rig right now. When I get some more time this week I am going to try and put my existing front in and play around with the back some more. I'd like the rear corners to taper in, since this is a frequent hang up point on the trails. We'll probably use 1.5" like we did on the front cage.
