how long is a yota shaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2004, 04:27 PM   #1 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
front drive shaft , I'm interest in both solid and IFS front shafts
I need a longer front shaft I know rockrat makes adapters for toy shafts so I think this route may work for me.
my second question is what size u joints do yota shafts use?
I'd just go to a salvage yard and take a tape out but i'm stationed on an island in AK and the one yard here doesn't have any yota's at the moment.
btw any one have one for sale
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 12-10-2004, 05:43 PM   #2 (permalink)
Member # 8111
I think the 79-85 was around 23" and the IFS was around 27" dont remember exactly though I know someone I postd pics and measurements of them here before..
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-672-9653
Rockrat is offline   Reply With Quote
Old 12-10-2004, 05:47 PM   #3 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
wow they are alot shorter then I thought... was think they were longer then a zuk front? do you know any thing about the u joint?
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
Old 12-11-2004, 12:52 PM   #4 (permalink)
Member # 37690
Send a message via Yahoo to blackrider
ya rockrat's correct the 85is 23" colapsed 27" extended to where the splines are just showing
the ifs is 27" on the truck with 2" extended
and if this helps,the #i got off one of my factory u-joints is koyo kc1720ad
the races come with the bearings,it's a set
4.3 vortec/tbi,yota axles/dual cases,40's,
stauns,oba,4 linked,coilovers,zook tub
[COLOR="blue"][SIZE="3"][FONT="Comic Sans MS"]NotQuiteRight Wheelers[/FONT][/SIZE][/COLOR]
blackrider is offline   Reply With Quote
Old 12-12-2004, 08:49 AM   #5 (permalink)
Member # 4877
Send a message via AIM to Squanto
You said you where LOOKING for a yota? There's a nice clean one for sale near me, but I'm in Kent, OH! Little far for a truck. Looks real clean, wooden bed that's dobe pretty nice, and a solid front. Not sure of the year, but I'd guess early-mid 80's.
03 Taco, BBP Rock Sliders, and some other junk. The Mall Krawler.
94 Trackick, dual cases, extended wb, 33's, welded rear, flat bed, still under the knife.
Squanto is offline   Reply With Quote
Old 12-12-2004, 04:17 PM   #6 (permalink)
jasonmt's Avatar
Member # 3236
IFS collapsed:
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote
Old 12-12-2004, 04:18 PM   #7 (permalink)
jasonmt's Avatar
Member # 3236
IFS extended:
Old 12-13-2004, 05:18 AM   #8 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
Yag has all the specs (with lengths) on tow=y shafts posted in one of the FAQ sections.
There is are several different ones.
The one I found I think was from an 85 xtra cab, but not sure because it was laying in the bed of the truck with a ton of other misc. toy parts.
It was a bolt in with CJ front springs in the rear.
EDIT: I looked but the lengths weren't posted. Here is what Rockcrawler posted in the thread - you should read the toy axle FAQ thread, there is info you can use there.
CV Driveshaft mod
While everyone looking for Toy CV driveshafts knows the 84-85 are the hot ticket, the later model IFS front CV shafts are cheap & easy to find, but because they dont have the same operating angle requirements as the solid axle counterparts, you need to do a relatively simple mod to gain the extra degrees of operating angle to make tham work in the Zuk application. I decided to go this route for my Toy axle conversion I am currently stockpiling parts for mainly because a buddy had a couple he was tossing in the trash because he didnt know about this mod.. and they were FREE! 4x4wire did a nice write up on the mod, check it out here & save yourself a bunch of $$$
http://www.4x4wire.com/toyota/tech/cvmod/
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 12-13-2004, 05:08 PM   #9 (permalink)
Member # 37690
i did the mod on a couple of 'em,pretty easy with a press,all that washer and bench vise stuff was really crazy.ended up with about 32 degrees operating angle
Old 12-14-2004, 10:51 PM   #10 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
thanks silve I looked and searched .. i even asked in the toy section first but they laughed at my zuk lol from what I gather i'm gonna have to have a custom shaft I need a base line of 33" i'm hoping for 10+" of spline I'm running 2.5 Cj's up front with m/l's my wheel base is 86" and i was also mistaken thinking toy's ran 1310 ujonts
mostlikey for now i'm gonna run an 2" extened yoke and 1 or 2 1"spacer ( have three now just to test fit the rig this will all be till I get down south ( out of alaska to the lower 48) next year and have a new shaft made
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
Old 12-14-2004, 11:07 PM   #11 (permalink)
Member # 5832
"I need a longer front shaft"
Pardon me if I'm reading all this wrong, but you are wanting a longer shaft for the front of your Sammy, right?
It looks like everybody is thinking you wanted to do the "usual" front Toy shaft put in the rear of a Sammy.
The 1985 front Toy CV shaft that I got is *exactly* the same fully collapsed length as a stock Samy rear shaft, and about 2" longer when extended.
It is nowhere near as long as a stock sammy front shaft, obviously. Most people then get a *rear* Toy shaft and then have it cut down to size for use in the front of a Sammy.
UZI 9mm is offline   Reply With Quote
Old 12-15-2004, 05:51 AM   #12 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
Go get a toy shaft and have it cut down to fit.
I can get a normal CV shaft shortened for about $40.
Lengthening depends on the shaft and how long.
Old 12-15-2004, 06:23 AM   #13 (permalink)
Banned
Member # 17128
Send a message via AIM to BikerSC
I think he needs a Toy shaft lengthened if anything.
-Steve
BikerSC is offline   Reply With Quote
Old 12-15-2004, 06:32 AM   #14 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
uzi yes i need a longer shaft so no silver a shorterned shaft is not gonna work .. however i was looking for the c/v of the toy front .. but since there are no place on this island that do shaft work .. i'm just gonna hold on till i get out of Alaska and make due with a extended yoke
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
