Zuk w/XJ's Front and Rear - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-21-2004, 06:07 PM   #1 (permalink)
AFTERMARKET4X4's Avatar
Member # 9464
Here are pic's of a friends Zuk. He installed a set of Cherokee rear leaf springs in the front and in the rear. It also has Missing-Link in the front and looooong drop bars in the rear similar to what Tim Porter uses. This thing flexes link mad!
Sean
84 Zuk....2.3 Liter Beater, 96 X-90 "looks like a crushed Red Bull can!"
“President Obama is the greatest hoax ever perpetrated on the American people,” Clint Eastwood
"This is the greatest wealth destruction I have seen by a president [obama]." Jim Cramer
AFTERMARKET4X4 is offline   Reply With Quote
Old 12-21-2004, 07:22 PM   #2 (permalink)
zuknstien's Avatar
Member # 31331
wow does that whole thing drop out in the back?
2 zuk buggys :D
hammer #1155
zuknstien is offline   Reply With Quote
Old 12-21-2004, 07:32 PM   #3 (permalink)
OKIE ZUK's Avatar
Member # 14812
I'd like to see it on a steep downhill, when he hits the brakes.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 12-21-2004, 07:50 PM   #4 (permalink)
Banned
CumminsZuk's Avatar
Member # 38228
2nd that
CumminsZuk is offline   Reply With Quote
Old 12-21-2004, 08:10 PM   #5 (permalink)
billjohn's Avatar
Member # 6668
Drop bars have been proven to work well when done right (Tim Porter, Jeff Pollock, and maybe a few others). But if you want insurance - add a limiting strap from the diff to the frame. This allows for all the articulation you want without allowing both sides to drop at once.
Bill Johnston
www.izook.com
billjohn is offline   Reply With Quote
Old 12-21-2004, 09:07 PM   #6 (permalink)
Member # 2752
Do you have a plain old side-shot to get an idea of wheel base and axle placement?
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 12-21-2004, 11:41 PM   #7 (permalink)
Member # 15689
seems like it would flex plenty with just the xj leaves. how much flex is to much? i've been pondering that question for awhile, and it seems it isn't as much as i used to think.
not bad for home grown
it's a little more than that sonny
bulletproof is offline   Reply With Quote
Old 12-22-2004, 06:13 AM   #8 (permalink)
Member # 8174
Send a message via MSN to Bill4rest
Ding ding
Bill4rest is offline   Reply With Quote
Old 12-22-2004, 08:23 AM   #9 (permalink)
SOBX2380's Avatar
Member # 23505
Send a message via AIM to SOBX2380 Send a message via MSN to SOBX2380
Yeah...me too!! I'm picturing a mechanical bull with a Sammi tub on it. WOOOOHOOO!!!! A center mounted limiting strap would be wise!
Nick
Tube Frame MiniKrawler
1979 Yamaha XS1100 Motor
Sammi axles
SOBX2380 is offline   Reply With Quote
Old 12-22-2004, 01:29 PM   #10 (permalink)
Member # 18975
t
lets see the pics of this thing flexin like mad
some jet skis
a boat
powerstroke on 40's on 20's
whats left of a 1986 sami with propane
wire ties and black primer thats how i roll
94SASMAZDER is offline   Reply With Quote
Old 12-22-2004, 03:18 PM   #11 (permalink)
Member # 16024
I have a friend with what appears to be a flatfender Jeep (only thing Jeep is the grill) that is running a setup like that out back - it works better than you might think - but he has some wheel hop issues (not axle wrap - bounce). He is going to run a set of coilovers with it to see if he can control the hop better. I've seen him step up on some stuff with that setup that the rest of us just sit back and look at...
Check out UCORA.org
VOTE or SHUT UP!
glfredrick is offline   Reply With Quote
Old 12-22-2004, 05:16 PM   #12 (permalink)
Member # 8351
I saw this zuk with the front tire in the sunroof of a honda and the rear tires on the ground . It works .
yes I look like Fred
jeeppartz is online now   Reply With Quote
Old 01-03-2005, 07:29 PM   #13 (permalink)
Member # 9464
Here's a few flexy pic's. This is all I have right now until the traction bar gets fixed:
Wish I had the one with the tire in the sunroof!
Sean DeVinney
Old 01-03-2005, 08:17 PM   #14 (permalink)
OKIE ZUK's Avatar
Member # 14812
Well, bulletproof, after wheelin' with Zukzilla4X4 last weekend, how much flex is too much.
Old 01-06-2005, 09:26 PM   #15 (permalink)
Member # 9464
Here you go. The real FLEXY pic:
Sean (Yes it's parked on a Sentra) DeVinney
Old 01-07-2005, 10:11 AM   #16 (permalink)
JCC
Member # 13845
Your right, that is Flexy. JC
88 Zuk. Spring over with RE YJ's Toy axles 5.29's welded rear Aussie up front. LC power steering,105 amp alternator, Short 33's Ramsey 9K qm Soon to have TT 6.4's
JCC is offline   Reply With Quote
Old 01-07-2005, 10:17 AM   #17 (permalink)
Member # 23056
That's wild. How can the springs twist so much under that kind of extreme articulation? Is he using something other than bushings in the spring eyes?
I guess a trac bar is a must for this kind of setup, even if you used 6 leaf YJ springs?
87 Sami: 1.6 16V, SPOA SR w/ YJs, locked 5.29 toys, 6.5:1 tcase, 35" MTRs, FJ60/Saginaw PS, Warn 8k
zukatude is offline   Reply With Quote
Old 01-07-2005, 10:31 AM   #18 (permalink)
NC Zuk's Avatar
Member # 12060
Send a message via Yahoo to NC Zuk
Yea, the setup has a goofey leaf/drop bar in the rear. It allows the spring eye to travel about another foot or more in the rear. Your right, it flexes like mad but I bet off-camber is not fun at all!
Front missing links
Rear drop arm
RIP MSG Art Lilley, you will never be forgotten...
NC Zuk is offline   Reply With Quote
Old 01-07-2005, 01:31 PM   #19 (permalink)
Member # 23056
Yeah, I understand the drop bar concept (really just a super long missing link). What I wonder about is as one side droops way down, the leaf spring has to start twisting. If that rear axle is at 45 degrees, the spring is really twisting and torqued up. Wouldn't this create some nasty leverage on the drop bar mounts or bushings and tear something off?
As for off-camber sidehills, wouldn't a limit strap help fix it?
Old 01-07-2005, 06:33 PM   #20 (permalink)
Member # 16213
-jack mode-
Are those 34" LTB's?
Shizuka is offline   Reply With Quote
Old 01-08-2005, 05:20 AM   #21 (permalink)
Member # 9464
Nope, 34 X 9.50 TSL's....AKA "Pizza Cutters". They came out years ago before the LTB's. Kick-Ass crawling tire.......but they SUCK in the deep mud!
Even though you can't read it, His License Plate says "ROK ZUKI".
Sean DeVinney
