dana 44 swap questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2005, 12:58 AM   #1 (permalink)
zukman27's Avatar
Member # 41559
is there any way to fit waggy 44s using sammy reaes up front and cj fronts in rear without moving spring hangers or cutting down axles want to avoid custom shafts so can be fixed with junkyard parts
zukman27 is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 06:48 AM   #2 (permalink)
Member # 37182
You can make the springs work, waggy are wider you would have to live with that
88.5 sami,stock type4
bogger61 is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 10:09 AM   #3 (permalink)
Member # 8690
Send a message via AIM to jp008 Send a message via MSN to jp008
No.
Have you looked at the top of the Suzuki Tech area??? There is a D44 FAQ up there.
Jim Phillips (D.O.R.)
87 Samurai-91 Kick
jp008 is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 11:27 AM   #4 (permalink)
Member # 41065
you can make it work. The axles will be wide, but that's cool as long as there aren't legal issues. You can get yokes that bolt to your t-case flanges so that you can use shortened wagoneer d-shafts rather than some crazy custom ones. You gain bigger u-joints in the deal as well, and it's not very expensive.
good luck
cuban b is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 04:51 PM   #5 (permalink)
Member # 8375
Send a message via Yahoo to Grumpy...
Where can one find these bolt on dana yolks? I need bigger u-joints...
www.grizzleyfab.com
Grumpy... is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 05:27 PM   #6 (permalink)
Member # 8690
good luck
I got some adapters from Rockrat and I am using the large Toyota flange. Much bigger u-joint than Sami and holds up to mucho abuse. At the diff side I am just using the 1310. The bolt on flange is a killer idea. If I had know of them I might have gone that route, but I would not have gotten the chance to meet Scott.
87 Samurai-91 Kick
Old 01-17-2005, 05:30 AM   #7 (permalink)
Member # 26206
Send a message via MSN to Terranaut
No .
The passenger side spring lines up right on the edge of the diff.You must outboard the springs .It isn't to big of a deal to do .
Like someone else said ..read the Dana44 area .
Terranaut is offline   Reply With Quote Quick reply to this message
