What causes "death wobble"? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2005, 07:54 PM   #1 (permalink)
Member # 39966
Send a message via MSN to utahsamiman
Angry What causes "death wobble"?
I am having some bouts of that wonderful massage lately. I am really hoping that it is mainly out of balance tires. What else could it be? Zuk is just 5" SPOA, stock shackles, so z-link should be like uh, at the like right angle.
Recovery points, is that the jeep thing??
utahsamiman is offline   Reply With Quote
Old 04-07-2005, 08:15 PM   #2 (permalink)
Member # 14492
You know that you are asking to get the big search lecture right? Seriously, there have been alot of threads which cover all the possibilities. Check your toe in, wipers and felt, kingpins, kingpin bearings, etc, everything in the front end. It seems like my death wobble has usually been atributed to loose wheel bearings, toe-in, or combination of both. Replacing the wipers and felt helps too.
BTW-SEARCH
HTH
Jerod
Jerod Gersch
Team Extreme Motorsports
XRRA #33
Toyo Rocks
Spider Nines
Poison Spider Customs
Precision Heavy Haul
zukiester1 is offline   Reply With Quote
Old 04-07-2005, 08:17 PM   #3 (permalink)
Member # 30444
hey utahsammiman i am also in salt lake and when i first did my spoa i dealt with the same thing. especially in four wheel drive. did you pull your drivelines apart at any point? do you have driveshaft spacers? those are the problems that i ran into.
1994 EFI Samurai, spoa, yj conversion, 33's, spool,etc.
1993 nissan hardbody, 2" body and 32's; for business
ChristianBenzon1 is offline   Reply With Quote
Old 04-07-2005, 08:21 PM   #4 (permalink)
ZUK
ZUK's Avatar
Member # 3301
Is the shimmy shock in good shape?
http://gearinstalls.com
2001 Taco auto 3.4L stock
ZUK is offline   Reply With Quote
Old 04-07-2005, 08:42 PM   #5 (permalink)
Member # 34491
What in the hell is a shimmy shock?
my_samurai is offline   Reply With Quote
Old 04-07-2005, 10:04 PM   #6 (permalink)
Member # 20384
I replaced my wipers and it didn't help my shimmy but at least I can see better now.
Owner ZukiCreations
zukicreations.com
ZukiCreations is offline   Reply With Quote
Old 04-07-2005, 11:09 PM   #7 (permalink)
brandonsfabwork's Avatar
Member # 43660
I think he's refering to the steering rag joint. Its a rubber type bushing that joins the steering shaft from the steering wheel to the shaft to the steering box. I dont think thats were the wobble is from though. Check wheel bearings, king pin bearings and your drive line if you dont have spacers after doing a spring over. get it fixed before driving it again so you dont kill anybody on the road. good luck
brandonsfabwork is offline   Reply With Quote
Old 04-07-2005, 11:14 PM   #8 (permalink)
Member # 17632
A steering stabilizer, maybe
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 04-08-2005, 03:53 PM   #9 (permalink)
ZUK
ZUK's Avatar
Member # 3301
ha ha....Travis got it.....guess you guys haven't been around long Anyways, do you have a steering stabilizer? It looks like a black shock tilted sideways and might be bolted to the pitman
Old 04-08-2005, 05:40 PM   #10 (permalink)
Member # 39966
I bet it is from my kings and birf and all. It is dry and kinda rusty. Its the only thing that I havent been able to get around to doing since I bought it. Anyone know where to get the kit?
Yeah I do have the steering stabilizer. Its probably stock. Is it better to fab new mounts?
BTW, I hate searching, but will get used to it. I dont have to wait until the next evening to get my answers.
Old 04-08-2005, 08:12 PM   #11 (permalink)
Member # 2752
Here are two threads for starters:
http://www.pirate4x4.com/forum/showt...t=death+wobble
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 04-09-2005, 08:01 AM   #12 (permalink)
Member # 12247
Keep in mind the TRE's wear out very quickly on a z-link.
Keep the rubber side down !
MuddMachine is offline   Reply With Quote
Old 04-09-2005, 11:12 AM   #13 (permalink)
Member # 39966
sorry TRE?
Old 04-09-2005, 04:08 PM   #14 (permalink)
Member # 12247
sorry TRE?
Tie rod end.
