Member # 43278
airing up tires
ok guys, what are you running to air up your tires? how long does it take? what size tires? any problems with the choice you made? and how much did it cost?
I am looking into some sort of way to air up my tires, 33x12.5 and am curious what people have. I am well aware of converting a york pump due to building one, problem is there aint enuf room under my hood thx to my power steering upgrade. I have heard of viair and companies that closely compare, my question is how is this any better than say a parts store pump ( i know cfm's and pressure, but if they are the same yet have a $100+ price difference, theres gotta be some secret right??) and yes I have tried the walmart $10 special---it did the job--not well, but when creative in the woods, I was able to even set a bead with it--i just want faster air up at the end of the day. |
Member # 42415
I had an old York 210 in my YJ and it would air up all 4 33's from ~8 psi to ~25 in about 10 minutes and that included walking around the Jeep!
I had friends that converted the rotary style A/C comp like the Zook has and worked just as well. About the same performance airing tires, but not enough CFM to run air tools like the York. If you can find a stock Zook A/C comp, the conversion should be less than about $100 with air hose and all ...
07 FJ - TRD SE - FOR SALE!!! / 01 XJ - 6.5"LA, 33" TSL's / 68 CJ-5 - In pieces ... |
Member # 16289
Only for airing back up, but I do the trick found on Chris' site under "Tech" "Cheap Tire inflator". It's kind of slow and certainly wouldn't seat a bead but it was cheap and convenient.
http://www.azrockcrawler.com |
I own this....it is really a pretty nice compressor. The only downside is that it has a 40min max runtime. If you do the conversion of the flowrate from liters per minute to cubic feet per minute if I remeber correctly it comes out to about 2.6cfm. Lots of good info on the site below about it and how it compares to the 'big boys'. I would HIGHLY recommend it if you arent going to go with a belt driven system or powertank
http://www.moabjeeper.com/superflow.htm
I break zuks and my wife fixes them! |
Member # 26553
I used 2 compressors from the air ride systems from Caddys. I picked them up at the local u-pull it for $15.00 each. 2 of them ran together was about as fast as a quick air 1 is at a fraciton of the price.
Member # 29534
I run a viair 350c with a 5 gal tank in my zook...but I use it occasionally for air tools too. The upside of the reservoir is that I can air up all 4 tires very quickly. The downside is that it takes up space.
Before I had the viair I was using the Wagan heavy duty compressor that Harbor Freight sells; cheap but I went through 3 of them in a year. They do honor the warranty though, and it's speed is decent for the price. I know a couple of people with power tanks and they seem to work great; you can save a few $$ buy getting the tank from your local welding shop, and buing the powertank regulator separately. Won't look as nice, but cheaper and works just as well. Hope my .02 helps...
My rig is a fusion of Jazz and Funk; I call it JUNK |
Member # 2752
Powertank for me too. Great for air tools on the trail too
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, ............. <>< <>< <>< Hey, if this rig is for wheelin', what are all these animal parts doin' in here? |
Member # 17632
I have a 4 cfm jobber from Foothill Offroad. It works good, I have a small 3ish gallon tank with it. If you look in the low-rider truck mags, you can find the same compressor in chrome even for $160. I think foothill gets like $260? I also have a 4 cfm unit from Extreme Outback. It looks identical, but it's on my shelf so I haven't compared the two.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 43278
check this out
ok after some research and some ebay shopping--lookie what i found--whatcha all think and even more important anybody have one? is it reliable? anybody have anything close for the $$
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW It's a PUMA 12 air compressor w/1.5 gallon tank he claims the specs are 125psi, 3.4cft @40lbs, 3cfm@90lbs--has all the pressure switches and such except its 12v with a 100% duty cycle. My idea is take the pump off the tank and remote mount the tank. heck I may be out of my mind--but maybe not so whatcha all think--any comparable products out there?? anybody own a PUMA product--what quality is it?? |
#12 (permalink) |
Member # 14922
That looks like much better than a couple hundred dollar Quick Air - or for that matter, 3 or 4 of the $50 compressors should move some air too. I have a Quik Air II but will be going CO2.
#13 (permalink) |
Member # 15422
The only downside to the powertank is during the winter some of the guys running compressed CO2 would have stuff freeze up on them. Probably wouldn't be a big problem out west during normal temps.
God's Area Code is "906" |
#14 (permalink) | |
Member # 29534
Had I seen that a year ago, I would have bought it instead of the viair 350c. No complaints about the viair, I work it a LOT and it keeps on going, but that compressor you found is rated for about 3x the airflow. I'd try it if I needed to buy one...
#16 (permalink) | |
Member # 7742
#18 (permalink) | |
Member # 15343
what if you used one of those bottle jackets like they use on NOS bottles maybe that might help.
DIRT, MUD, ROCKS WHATEVER!!!! |
#19 (permalink) |
Member # 43278
my thoughts on homemade tank
ctbrent no offense to you or anybody who ownes a tank--but im not a person that likes 1000lbs+ of air in my vehicle waitin to pop the regulator off and make a rocket. How exactly you plannin on mounting the soda co2 tank safely meaning if you tip/roll/ or even hit a good bump---whats gunna keep that regulator safe.
I found that compressor which would well for me--especialy since I can fill the tanks when the vehicle is parked and air up safely--rather than having a possible projectile in the back (other than my normal crap bouncin around )my $.02 on that |
#20 (permalink) | |
I really feel that having crap bouncing around is a lot more dangerous than a well secured and neatly set-up rig. A good buddy of mine was almost decapitated by the items in his tool bag that weren't secured when he went over in Moab. His cab was torn apart from all the tools bouncing around. Now he keeps everything strapped down. Everything has it's place. It took a severe concussion for him to learn it. I have seen what those bottles can do yet I am not worried. I believe if you take proper precautions it can be perfectly safe. |
