radiator help
ok ive searched around and havent really found what im lookin for. i just put a 1.6 8v in my sammy. i am running the stock sammy radiator in it now but it is running waaayy too hot. ive heard that the stock radiators will cool a 1.6 fine but would it matter that i have a sumo 2 head on it and a header? plus i live in az
or do you think my problem lies elsewhere? also if i do need a bigger radiator what can i run in it that will still fit? thanks in advance.
Member # 8111
put an electric fan on it. Completely remove the stock clutch fan. Problem solved
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#3 (permalink) | ||
Member # 16608
I'd try Rockrats pusher fan idea first though.
'88 Zuk |
Member # 8111
We used an off the shelf autozone electric fan 12 or 14" it just fit the radiator section.
#6 (permalink) | |
Member # 2752
A good electric fan is the ticket for cooling, unless/until it stops working......
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, ............. <>< <>< <>< Hey, if this rig is for wheelin', what are all these animal parts doin' in here? |
Member # 16764
from what I recall the 1300 radiator is ok for the 1600 16 v not for the 8 valve. I am shure there are those who have done it. A modded 8 valve is probably worse yet.
The options I know of are the Trail Tough 3 core radiator (last I knew they were the cheapest for them) or kick / tracker 2 door radiator requires some custom work to fit it.
i live in a world of stupid people and smart phones |
#12 (permalink) | |
Electric fans
#13 (permalink) |
ok now im really confused. im pretty sure now my samurai is just possesed. i went out and got me a 12" electric fan from auto zone. fabbed up some new radiator mounts so the fan would fit as a pusher. so i fire it up and let it sit. it gets to about half way and stays there at idle. so i drive it down the street and come back and it gets to about 3/4 of the way on the temp guage and just stays there. so i figure the fan must be working cause its keeping it at this temp. so i shut the fan off and the temp guage drops down to 1/2 way. turn the fan back on and it goes to 3/4. turn it off and back down to half. what the heck is up with that?
