What's your trick for removing gasket material?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-16-2005, 06:15 PM   #1 (permalink)
Member # 42214
What's your trick for removing gasket material on aluminum surfaces like the head and intake manifold??
That gasket material is pretty stubborn stuff... Thanks to all who take the time to reply..
badzook
badzook is offline   Reply With Quote
Old 08-16-2005, 06:17 PM   #2 (permalink)
Member # 46549
puddy knife- the plastic ones. they also make gasket remover at usual parts houses
Mr_DIY is offline   Reply With Quote
Old 08-16-2005, 06:18 PM   #3 (permalink)
AFTERMARKET4X4's Avatar
Member # 9464
Right angle die grinder with gasket removal disc (looks like Scotchbrite on a disc). Works like a charm!
Sean
84 Zuk....2.3 Liter Beater, 96 X-90 "looks like a crushed Red Bull can!"
“President Obama is the greatest hoax ever perpetrated on the American people,” Clint Eastwood
"This is the greatest wealth destruction I have seen by a president [obama]." Jim Cramer
AFTERMARKET4X4 is offline   Reply With Quote
Old 08-16-2005, 06:22 PM   #4 (permalink)
Member # 36499
sharp putty knife( round over the corners)
expertly handled so as not to gouge the Al surfaces
and
throttle body cleaner to soften it up before scraping. Working w/ a shopvacuum handy helps to get the strays that might go where they shouldn't.
DOn't forget the rags over the pistons .
1bille1 is offline   Reply With Quote
Old 08-16-2005, 06:39 PM   #5 (permalink)
Member # 16608
Sean
Yep...these little babies right here.
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 08-16-2005, 06:49 PM   #6 (permalink)
Madzooki's Avatar
Member # 13569
Send a message via AIM to Madzooki Send a message via Yahoo to Madzooki
I use those all the time. Work great.
Paul
"If it doesn't fit, get a bigger hammer"
Madzooki is offline   Reply With Quote
Old 08-16-2005, 07:54 PM   #7 (permalink)
Member # 38527
Send a message via MSN to sj-x
believe it or not, sometimes when the gasket is hard and kinda GLUED on to a block, a SMALL ball peen hammer can do wonders. just a few light taps and it starts to lift off.
on steel surfaces, you can use an air powered gasket chipper, I LOVE EM. can be used on alu., but carefully.
sj-x is offline   Reply With Quote
Old 08-16-2005, 09:31 PM   #8 (permalink)
tanzuki's Avatar
Member # 15771
Send a message via ICQ to tanzuki Send a message via AIM to tanzuki Send a message via Yahoo to tanzuki
I personaly wouldn't be beating or taping on a gasket mating surface with a hammer but that's just me.
tanzuki is offline   Reply With Quote
Old 08-17-2005, 01:28 AM   #9 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
brake clean and a razor knife..
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 08-17-2005, 05:50 AM   #10 (permalink)
speedo's Avatar
Member # 23262
Sean
When I first started using those I had a recurring job that took about an hour just to do the gasket removal. After I started using the right angle grinder and the discs the time went down to less than 10 min. Part of the job involved an aluminum housing. Those things are a must have part of my tool box now and I've been using them for something like 15 to 17 yrs.
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is offline   Reply With Quote
Old 08-17-2005, 02:01 PM   #11 (permalink)
turd-polish-a-go-go
LittleBlackSambo's Avatar
Member # 49404
i concur. be careful with abrasives as well.
try this one: aerosol oven cleaner.
thanks for the compliment, but it's not a jeep.
LittleBlackSambo is offline   Reply With Quote
Old 08-17-2005, 02:24 PM   #12 (permalink)
Member # 13806
Use the die grinder pads with caution, too much pressure will cause uneven surface-especially on the head-as aluminuim is very soft and can cause block separation.
RokNRollr is offline   Reply With Quote
Old 08-18-2005, 07:38 AM   #13 (permalink)
Member # 27316
Where can you get those?
85/90 Ford cab truck, 302 HO, C6, Atlas 4spd, D60HP, 14 bolt, lincoln front, detroit rear, 4.88's, 42 TSL's
87 Samurai, modified
[QUOTE=60seriesguy]*For the most part*, East Coast wheelers seem to share the mentality that unless the truck looks like Godzilla ate it and then shit it, then it's not hardcore.[/QUOTE]
DRKelly is offline   Reply With Quote
Old 08-18-2005, 02:25 PM   #14 (permalink)
Member # 29991
That's a good one for polished hard black remnants. Also try carb cleaner. It soaks in, softens, and makes the paper puff up. After I get all I can get w/o taking aluminum too, I try the carb cleaner on the rest. Sometimes I also use a stiff wire brush to rough things up. At the git-go I also use a dull paring knife for most, then a razor blade of some sort for hard stuff. It is easy to mess up the aluminum with razor blade. Not THAT easy, but be aware. For large pieces of hard gasket I sometimes rough it up with judicious use of a hacksaw blade. Think I have used a torch in some cases too. Think I have used a carpenter's plane a few times in special cases.
"The care of human life and happiness and not their destruction is the first and only legitimate object of good government."
--Thomas Jefferson, 1809.
GeoB is offline   Reply With Quote
Old 08-18-2005, 05:48 PM   #15 (permalink)
Member # 9464
Most any auto parts store carries them now. I get mine from Advanced Auto Parts here in VA.
Sean
Old 08-18-2005, 07:48 PM   #16 (permalink)
Member # 38527
you both need to stop and think about that one.. i'm not talkin using a 2 lbs hammer, i mean like 16 oz ball peen or smaller. it works very nicely, and oven cleaner, brake clean, gasket remmover etc.. is fine if you can get at it, but often times i am on a creeper doing this driectly above my head on a pan gasket (cat) and gettin that oven cleaner in your eyes really hurts. and if it has an isloation cover, it usually hangs too far down to use discs, just too damn close. also, *oem* states that you should use blue discs *fine* on alum. otherwise be careful! the coarse ones put waves in alum very quickly and will cause leaks.
Old 08-19-2005, 03:14 PM   #17 (permalink)
Member # 20077
i have used a wire wheel and a drill b4, works good.
PROJECT : [url=http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=52024]HYPO_ZOOK[/url]
hypolux is offline   Reply With Quote
Old 08-19-2005, 04:53 PM   #18 (permalink)
Member # 16608
Originally Posted by hypolux
i have used a wire wheel and a drill b4.
Gotta' be cautious with this route...don't do intake gaskets, or anything internal this way...Iv'e taken more than one seized engine apart...checked the oil pump, and it was locked up from those little wires that had came off one of those wheels.
'88 Zuk
