engine relay questions?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2005, 12:57 PM   #1 (permalink)
Mung Bung
scO44's Avatar
Member # 16080
couple of questions.. my 92 sammi turns over but has no spark. the coil has power, but the distributor doesn't. i traced the dist. wires back and one runs to the computer and one to the main engine relay, and one is a ground. the engine relay has power into it but none is returning to the dist. Questions: what would cause the power not to go to the dist.? how often do these relays go bad? all my grounds are hooked up, but if i added another one where should i put it?
Thanks
any info would be great.
-Ghost ride the whip while you ride tha strip..
scO44 is offline   Reply With Quote
Old 09-26-2005, 01:59 PM   #2 (permalink)
Member # 49944
did you try your computer had the same problem a couple of months ago turned out it that was the trouble. as for the relay had i know a guy up the road from got a 91 sammy for cheap thought the computer was gone but it was a relay gone. he said he swaped the two relay that are next to each other and turned it over and got spark on the wires so he got a nother relay it ran best kind.
sam709 is offline   Reply With Quote
Old 09-26-2005, 02:33 PM   #3 (permalink)
OKIE ZUK's Avatar
Member # 14812
Ditto on the computer.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
