Hydro assist part #'s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-05-2005, 09:28 AM   #1 (permalink)
Member # 44418
Heres a list of the part #'s I used to put hydro assist steering on my Samurai.
Total cost less shipping is $75.83
If you dont allready have power steering on your machine, Then it will cost more than this, But I allready had power steering.
http://www.surpluscenter.com/item.as...=1&item=9-6645
Hydraulic cylinder 49.95
http://www.surpluscenter.com/item.as...name=hydraulic
Fittings need two sae 4 to 1/4 NPTF 1.69 each
fittings need four 1/4 NPTM to 1/4 NPTF swivel 1.95 each
Hoses need two 1/4 NPTM soild fitting 36" long 7.35 each
IF IT HAS'NT BROKE YET. GIVE IT TIME. IT WILL!!!
jader is offline   Reply With Quote
Old 12-05-2005, 11:18 AM   #2 (permalink)
GRW
Member # 9515
Assist, do you have more/better pictures showing everything?
Thanks
GRW is offline   Reply With Quote
Old 12-05-2005, 11:53 AM   #3 (permalink)
Member # 44418
Thanks
I didnt put up any other pictures, because there is so many other guys on this board that have already done this and are alot of pictures on here if you look for them. I was more tring to put out the part #'s of the parts used to do the job. I found parts cheep I thought I would share.
However If you want more pictures of my set up I can get you some No problem. What do you need to see more clearly?
Old 12-05-2005, 12:07 PM   #4 (permalink)
Member # 9123
What steering box you running?
Metal to burn, sparks to fly...
Damo is offline   Reply With Quote
Old 12-05-2005, 12:36 PM   #5 (permalink)
mrbogger's Avatar
Member # 25568
Thats some good INFO THANKS
TUBED OUT SAMMY 4.3 TWIN TOY CASES TOY AXLES 529s 39.5 IROCs
mrbogger is offline   Reply With Quote
Old 12-05-2005, 01:31 PM   #6 (permalink)
Member # 44418
Running Toyota Celica pump with restrictor drilled out to 13/64''. Celica steering gear. And two toyota resivors, Removed the top of one resivor, cut the bottom off the other and welded the two together. Cut off the upper resivor return line and welded hole closed.
Old 12-05-2005, 01:51 PM   #7 (permalink)
Member # 29923
man thats awsome...ive been looking at doing hydroassist for a while now...do you have any idea if it will work with other boxes (ie a 95 chevy box) and how quick is the steering response?
pbmang is offline   Reply With Quote
Old 12-05-2005, 03:52 PM   #8 (permalink)
Member # 44418
This cylinder will work with any steering box. Two of my friends are using this same cylinder and both are running chevy boxes.
Response is great no delay.
Old 12-05-2005, 06:13 PM   #9 (permalink)
catzuk's Avatar
Member # 44135
thanks for the info! Its 2 below zero outside, be a good time to finally do the hydo assist. Did you modify the ends of the ram at all like some have done for rod ends? Doesn't look like it in the pic. And did you tap the celica box your self?
87 Zuk, dana 44's w/5:38 detroits,coils/3 link frt, 3 link rear 37" Krawlers
87 Zuk, SPOA, Lockright/spool, 31" Truxs MT's. shaved and trussed stock axle housings,1.6/w 1.3 head, fuel injected, 4.16 t-case
88.5 Zuk future project pending
catzuk is offline   Reply With Quote
Old 12-05-2005, 08:19 PM   #10 (permalink)
Member # 29923
excellent, i just ordered my stuff...as far as drilling and tapping...what size bit and tap did you use? i would assume a 1/4, but what threads for the tap?
and where do you tap the box?
sorry for the noob questions and thanks
Old 12-05-2005, 10:19 PM   #11 (permalink)
Member # 44418
I only modifyed the body end of the cylinder with a heim joint. On the shaft end, I Cut the sleeve down (with sawall) so the sleeve was as wide as the tie rod is in diameter. That way the plates welded to tie rod come straight off tie rod.
After I was done I know I could have made both ends that came on cylinder work. Just need to mount in a way that both piviot bolts would be vertical and cylinder would be parallel to tie rod.
I didnt really need heim joint.
And yes I drilled and tapped the Celica box myself.
Old 12-05-2005, 10:30 PM   #12 (permalink)
Member # 44418
Drill hole to 7/16'' and tap with 1/4 NPT tap.
This is were I drilled and tapped.
In the pictures you can see I didnt use the hoses from surplus center, Only because I can make them myself at work. My hoses are about 34'' long so the 36'' long hoses from SC should work fine.
This is the info I followed for drill my steering gear and pump mods.
This is for a toyota IFS gear, But the Celica Gear is the same just smaller.
http://board.marlincrawler.com/index.php?topic=10579.0
Old 12-06-2005, 05:36 AM   #13 (permalink)
Member # 44418
Heres the doubled up resivor I built. Very cheep and easy to do. I feel its a must do when you add hydro assist.
Old 12-06-2005, 10:15 AM   #14 (permalink)
Member # 41630
Send a message via MSN to psychosam
excellent thread, your giving me stupid ideas about doing this to my TINTOP, I LOVE STUPID IDEAS,
what year is that celica steering box? Mid 80's? Also what motor you running in your truck?
psychosam is offline   Reply With Quote
Old 12-06-2005, 04:36 PM   #15 (permalink)
Member # 44418
Steering box came off a 1979 Celica. I have 1998 1.6L 16V sidekick motor.
Old 12-06-2005, 04:56 PM   #16 (permalink)
Member # 44418
I have to update my parts list.
Insted of ordering 4 of these fitting.
1/4NPTM to 1/4NPTF 90 degree swivel.
Order 3 but then order one of these in place of the 90 degree fitting.
1/4NPTM to 1/4NPTF 45 degree swivel.
I was looking at mine again and figured that a 45 degree fitting into the side of the gear would make connecting hose alot easer.
You can see in the picture, I used a hose with a crimped on 90 degree fitting attached to hose. The hose from Surplus center has a straight fitting end. So I think a 45 degree fitting threaded into gear in this location will work better.
Sorry about that one guys. I should have caught that one.
Old 12-06-2005, 05:33 PM   #17 (permalink)
Member # 41630
wow 79 celica, thats gonna be a hard box to find. but i'm sure i can find one, i work for a major import auto wrecker where i live.
Old 12-06-2005, 05:34 PM   #18 (permalink)
Member # 41630
Old 12-06-2005, 05:57 PM   #19 (permalink)
Member # 44418
You can get the steering box off of 78-81 Celica,Corona,and Cressida.
all are the same.
That should make it easer to find.
Old 12-06-2005, 07:59 PM   #20 (permalink)
turd-polish-a-go-go
LittleBlackSambo's Avatar
Member # 49404
great thread, outstanding help. now i can go broke just in time for christmas... my family will understand. thanks alot. now i gotta do my holiday shopping at the goodwill.
psychosam, i got my celica box for $75 us delivered. found it on www.car-part.com car part is a national junkyard registry. they have a huge amount of canadian listings as well.
thanks for the compliment, but it's not a jeep.
LittleBlackSambo is offline   Reply With Quote
Old 12-06-2005, 08:46 PM   #21 (permalink)
MOSDIF589's Avatar
Member # 41378
Great thread.... I've wanted to do this but didn't have the budget for it right now with "CHRISTmas" and all... I have the same steering you have and was going to install it next week, glad you posted this I'll get the extra parts to do it all... I got a used RRO power steering kit that he had on his 1.3ltr do you know if that will work on my 1.6ltr 16valve ?? What kit are you using for the kick pump to attach to the motor ?? Thanks again for the info... MOSDIF589
2004 RUBI w/D60's 39" I-ROk's blaa blaa blaa
PAINT IS LUBRICANT AND LUBRICANT IS GOOOD
MOSDIF589 is offline   Reply With Quote
Old 12-06-2005, 09:10 PM   #22 (permalink)
ZuksRule's Avatar
Member # 8392
Awesone thread. Thanks alot. I have been running the '79 celica box and pump for a couple years now and just this morning i decided wanted to look into hydro assist, i came here and found this. Perfect!
ZuksRule is offline   Reply With Quote
Old 12-06-2005, 10:57 PM   #23 (permalink)
Member # 44418
You said ''I have the same steering you have'' But then you asked what kit I'm using to mount the ''kick pump'' Is that just a typo??
I'm running toyota pump and gear.
The RRO Toyota power steering pump bracket for the 1.3L motor will not bolt onto the 1.6L 16V motor.
The exhaust manifold on the 1.6L is larger than the 1.3L. The RRO pump bracket mounts very close to the exhaust manifold on the 1.3 motor. Exhaust manifold is in the way on 1.6L
I built my own pump bracket for the 1.6L 16V motor. The bracket is a componation of the stock Celica bracket and some modifing by me.
The pump pulley is from a Toyota tercel and the ideler pully is off some Mazda car. Dont rember witch one.
Tercel pulley does not fit right on Celica pump. I had to drill out center of pulley for pump shaft diameter and file out the key way a little, but it was very easy to do.
Dont know if the pictures show much, but this is the pump bracket I built.
The bracket I build will fit on both the 1.3L and the 1.6L 16V motors. Heres another one I built but on a 1.3L motor.
Old 12-07-2005, 06:32 AM   #24 (permalink)
catzuk's Avatar
Member # 44135
Again, the info has been great! Thanks! I've been running the celica box for several years now, but I decided to go to the sagnaw pump from a waggoneer after my toy pump died. Lots of fluid now and no problems of heat. Turns 35's easily except in the roughest terrain crossed up. Looking to go to 37's and want to relieve some stress from the box and other parts. So hydro assist is the way to go for me.
Old 12-07-2005, 04:40 PM   #25 (permalink)
Member # 44418
Did you only swap out the pump? Or did you swap both the pump and the steering gear?
Just wondering. I dont think the weak link is the Celica gear, I know the Celica pumps can fail, blow fluid out the front seal and so on, But I've never seen the gear fail. And now with the hydro it should take alot of the work load off the gear.
