Spring Eye Bushings - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2005, 08:56 PM   #1 (permalink)
Member # 62837
Spring Eye Bushings
I just got my yj springs and i am having a problem with the bushings. Most of the bushings are rotten, and a few of them still have the bolt rusted inside of the metal sleeve.
I am gona buy a new spring eye kit, but what is the best way to go about getting the old ones out? I was thinking of burning them, but i would need a torch. Also, i have heard that rubber burns at such a high temp that you need to keep putting the flame out so it doesnt warp the metal.
Any help or solution would be greatly apprechiated!
88 Samurai, 104WB, Locked Up Yotas, 6.5's, 36's.
Chop and stretch: [URL="http://www.pirate4x4.com/forum/showthread.php?t=643403"]http://www.pirate4x4.com/forum/showthread.php?t=643403[/URL]
[QUOTE]I blew through two D60's ring and pinions, and three sets of superior shafts. I run 42" tsl's, and finally stepped up to a Cryo'd D30..... I will never look back[/QUOTE]
dabomb5756 is offline   Reply With Quote
Old 12-18-2005, 09:27 PM   #2 (permalink)
Member # 26536
Burn out the center and then sawzall the outer metal cup from the inside and then press them out. With a BF hammer or with a press. Let it burn baby.
flexmonger2 is offline   Reply With Quote
Old 12-19-2005, 03:07 AM   #3 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
I've used a big drill bit in reverse it heats the bushing and comes out not to bad then cut wats left with a sawzall if not
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 12-19-2005, 05:48 PM   #4 (permalink)
Member # 41861
use a hole-saw...no fuss, no muss
MicroZuk is offline   Reply With Quote
Old 12-19-2005, 05:59 PM   #5 (permalink)
Member # 62837
If i had one....
I have been to a guy who owns his own little spring shop. He has done some work for me, and i have sent a few friends to him for ubolts, springplates and other various parts.
I might be able to go over there and do it with him as long as i slip him a 10 or somthing.. Maybe i can learn something for next time and share it here.
Old 12-19-2005, 06:28 PM   #6 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
Originally Posted by dabomb5756
If i had one....
hole saw $15 at home depot
mini torch $20 ..
git r done
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
Old 12-19-2005, 06:32 PM   #7 (permalink)
Member # 37709
I used a drill bit, maybe 5/16", and drilled through the rubber. I put enough holes in it that I could then drive it and the center bushing out. I wish I had a sawzall to cut the outside metal cup out but I didn't. I took my hack saw blad off and then reassembled it with the blade going through the spring eye. I cut a groove in the outside cup then bet it out with a BFH and chisel. Needless to say I was hating the idiot that designed those buishgs, but the ride makes it all worth while!
Bearkat is offline   Reply With Quote
