Anyone running toy running gear? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-21-2001, 01:03 PM   #1 (permalink)
Member # 5928
Send a message via ICQ to x2_rage Send a message via AIM to x2_rage Send a message via Yahoo to x2_rage
Post Anyone running toy running gear?
I own a toyota and use to own a samurai. I have been thinking about getting a sammy body and frame and putting my engine/tranny/t-case and axles under a samurai. I know tons of peopel that have put the axles under, but I am wondering about putting the engine and tranny in. Has anyone done this? How much space did it leave you in the engine compartment and for the rear driveline? How hard was it to wire up the block? I run a carbed 22R . . .
RAGEx2
_ _ ____ _ _
'95 XJ
'00 TW 200
'86 Samurai
'84 Toy
'92 YJ
x2_rage is offline   Reply With Quote
Old 09-21-2001, 01:10 PM   #2 (permalink)
fatkid's Avatar
Member # 4862
Post
Next your going to want to extend the wheel base, then your back to having a Toyota. Why all the work?
[url]http://www.myspace.com/jerrywsparks[/url]
fatkid is offline   Reply With Quote
Old 09-21-2001, 01:26 PM   #3 (permalink)
Member # 5928
Post
Well, I liked driving a samurai more, because of the following;
1) Shorter wheelbase
2) Better turning radius
3) Better visibility
4) Jeep body style
5) Lighter weight
6) And I just darn like Samurais
I knoew I would have to lengthen the wheelbase a bit, but would it realy be that much? I thought about the possibility of only having to slide the rear axle back about 3-4" or so . . which would just mean I would build a bigger bumper and put the shackle hangers on it.
I dunno, I just wanted to seeif anyone's done it yet. When I did a rough measurement from the front of my motor to the rear flange on the t-case, it looked to be only a few inches longer than the sammy setup ( my neighbor has one).
RAGEx2
_ _ ____ _ _
'95 XJ
'00 TW 200
'86 Samurai
'84 Toy
'92 YJ
Old 09-21-2001, 01:35 PM   #4 (permalink)
fatkid's Avatar
Member # 4862
Post
I can take a measurment this afternoon, we have a 85' with the cab off sitting at the shop. <IMG SRC="smilies/smile.gif" border="0">
Old 09-21-2001, 06:26 PM   #5 (permalink)
Member # 5928
Post
THat would be kewl! I am guessing it is almost the same, since there is a driveline between the sammy tranny and the t-case, and there isn't one on the toy. Shortening the rear driveline no more than 2-3 inches isn't bad, but I won't go beyond 3". So, if the length was about 7" off total, I could slide the rear axle back 4", shorten the driveline 3" and be set. I have just invested so much damn money in my toy drivetrain, I don't want to have to start over with a 1.3 again . .
RAGEx2
_ _ ____ _ _
'95 XJ
'00 TW 200
'86 Samurai
'84 Toy
'92 YJ
Old 09-22-2001, 12:27 AM   #6 (permalink)
fatkid's Avatar
Member # 4862
Post
I measured around 75", thats from the fan to the flange on the t-case. Now take about 6.5" out that because it has a double stack. If that's any help.
Old 09-22-2001, 03:07 AM   #7 (permalink)
Member # 2143
Post
Al Berikoff runs toyota running gear in his sami ( now " jeep " ) basically kiss goodbye to the inner fenderwells and prepare to cut and replace the trans tunnel, replace the <IMG SRC="smilies/rainbow.gif" border="0"> tube front crossmember with something a little more substantial ( and further forward) and run x-over steering ( or go Over The Top... <IMG SRC="smilies/biggrin.gif" border="0"> ) and ditch the stock steering box for a toy IFS P/S unit.....( Al runs a full hydraulic setup...)
Al's truck with 35" boggers on it was one kick ass machine....and with the wheelbase extended and the stability of the wider axles he could attempt some pretty krazy shiot......you won't be sorry if you do this........Ben
AIRZUKI is offline   Reply With Quote
Old 09-22-2001, 01:42 PM   #8 (permalink)
Member # 5928
Post
fatDRM, the 75" measurement is for the toy setup right? Anyone want to measure a samurai length for me?
RAGEx2
_ _ ____ _ _
'95 XJ
'00 TW 200
'86 Samurai
'84 Toy
'92 YJ
Old 09-23-2001, 01:29 AM   #9 (permalink)
fatkid's Avatar
Member # 4862
Post
yup, thats with a double stack. <IMG SRC="smilies/smile.gif" border="0">
Old 09-23-2001, 01:20 PM   #10 (permalink)
Member # 5928
Post
Yea, I won't be running a double stack, too long! Although dual marlins rule. Cutting of the inside of the fender wells makes sense since the block is a bit wider. I wonder how much of the trans tunnel needs to be cut though. Not that it would be hard to get some sheet metal and make it wider. WIsh someone had some pics . . . .
RAGEx2
_ _ ____ _ _
'95 XJ
'00 TW 200
'86 Samurai
'84 Toy
'92 YJ
