Member # 44424
carb frosting
i have a solex 34/34 on my stock sammi.when it snows it would start flooding.took of the breather and noticed frost around the venturi.it almost covered it all except for the small center hole.is there any way to prevent this from occuring.any help please.
#2 (permalink) | |
Member # 29991
Probably this is a well-traveled road and what you want prolly is readily available. Maybe ask the VW people as they are into Solex and Zenith. Maybe, like the airplane people, you might want a manual control on the carb heat. You could use it when needed only. I wouldnt, but some might like it this way. It does cost you some potential power. Not like it consumes power, which would lower your mpg, but it provides a less-dense air flow so less O2 gets into the cylinder. But the warmth helps 'atomize' the fuel, thus contributing towards a more complete burn and better mpg. And a cleaner running engine.
"The care of human life and happiness and not their destruction is the first and only legitimate object of good government." --Thomas Jefferson, 1809. Last edited by GeoB; 02-06-2006 at 09:41 AM. |
#3 (permalink) | |
Member # 66028
I own an UMP air cleaner and will be installing it this spring. Still haven,t figured out the best way to do the warm air option yet. |
Member # 48911
are you still using the stock heat-jacket around the exhaust manifold with it's tubing still plumbed into the stock air intake with it's little heat controlled valve? It may work for you if you're not. usually it's the first thing to go. But if it's that's cold, you probably need it. also, if you have that much moisture in the air at night, you may want to have the end of the air intake tube handy, so you can plug it at night and stop the moisture from becoming frost down in there. We're really humid down here in the swamp, but we don't see that kind of cold. right now it's about 75 and sunny. bet you northern boys are jealous right now. It'll be my turn when it gets 115 plus 145% humidity. I don't care what they say, the heat index is more like 200.
Member # 44424
thanks,i have been thinking of building my own breather that incorperates a powerstering cooler off of the original water choke lines.if i get it done i`ll post some picks.my sammy is a daily driver.40 miles to and from work.bad weather is the reason for pucharsing my sammy.freinds at work are enveous of my 28 mpg and supiror 4*4 capability.
Member # 38974
I have had this same problem in the fall on humid days.
On the highway at almost full throttle, the secondary had not opened up yet.....the venturi would start it ice up. overnight frost is not the problem, think about how fast air is going through your carb, and what the wind-chill effect would be like, if you are having this problem you really need to supply the carb with warm air. the sj410's used to have a wing nut, on the air box that you would adjust for winter or summer, the sammi has a thermal / vacuum operated baffle. maybe yours is not working. note : i'm runiing efi now and will never go back to a carb. later Steve Last edited by 85sj413; 02-06-2006 at 06:38 PM. |
Member # 48911
One would think that the carb, sitting atop a water-cooled intake, would stay warm enough keep defrosted. And I think wind-chill only applies to things that evaporate water, like people. But it's true that fast moving air out of a valve stem will cool it tremendously and frost on the outside. I can't imagine the motor sucking that much air through there to do that. If you are, then you're getting good power with all that dense air charge.
Member # 29991
The evaporating fuel, as well as the expanding air create the low temps. I think primarily the evaporating fuel.
I don't think you can count on the air being denser; because it is being sucked into the manifold, which lowers the pressure, allowing it to expand and cool. Cool = dense, low pressure = not dense The cooler and lower pressure maybe have a linear but opposite relationship which cancel each other out. [Hijack on] TBI injection makes for a heavier mixture in the intake runners, requiring more energy to get it all into the cylinder, compared to port injection. Dry intake runners have lighter air in them and this makes for big tuning differences. Also the fact that the fuel isn't present to be worried about puddling or something also effects the tuning possibilities. I am building a MegaSquirt controller, thinking that one day I may switch from the TBI to port injection. 'Bout alls I would have to change would be to add bungs and injectors to the manifold. [Hijack off] But what do I know?
"The care of human life and happiness and not their destruction is the first and only legitimate object of good government." --Thomas Jefferson, 1809. Last edited by GeoB; 02-07-2006 at 08:54 PM. |
Member # 64356
If you wand to get a good idea when carburetor icing is most likely take a look at the chart on this page http://www.ez.org/carb_ice.htm . If you are looking for a cheap way to deal with carb ice go to a local airport and ask an aircraft mechanic if you can look at how the systems work on small planes. It could not be made any simpler then the system on mine. The problem with planes is that the intake air when carb heat is selected to on position is NOT FILTERD at all. If you feel like building a manual control system that could incorporate a filter and only use it when needed.
