Bad Heater Core ..? Blows cold on freeway - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2006, 09:52 AM   #1 (permalink)
Member # 65077
I have a 86 Tin top, runs and drives good, Just a couple of problom's,
My heater doesnt work Does anyone know were the valve on the firewall is located ?
and or how to clean out a heater core ? and the location of the heater core?
im new to the world of sammi's
thanks
93liftedxlt is offline   Reply With Quote
Old 02-13-2006, 10:17 AM   #2 (permalink)
Member # 2752
The heater valve is located on the upper firewal on the passenger side. The heater cores are prone to getting a bunch of junk in them. Search and you will find some pretty good how-to writeups on cleaning them out.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 02-13-2006, 10:20 AM   #3 (permalink)
Member # 5832
This thread is well worth reading
http://www.pirate4x4.com/forum/showt...ht=heater+core
UZI 9mm is offline   Reply With Quote
Old 02-13-2006, 11:26 AM   #4 (permalink)
Member # 65077
thanks, i really appreciate your help
Old 02-13-2006, 12:39 PM   #5 (permalink)
Rudezuk's Avatar
Member # 4500
Also check your thermostat...
If you have a bad one or one that sticks open, it wont keep the engine at normal operating temp. I found that out when I took my old zuk on a snow run, and i froze my ass off!
Shane
[COLOR="DarkRed"][FONT="Comic Sans MS"][URL="www.hbrk4x4.com"]HBRK4x4.com[/URL][/FONT][/COLOR]
[URL="http://www.yyracing.com/"]Y&Y Racing, LLC[/URL]
[URL="http://www.we-rock.cc/team_list.php?wts=show&wvalue=181"]We-Rock #208[/URL]
"Team HBRK" thanks our sponsors.
Driver: Shane Yost
Spotter: Todd Young
Rudezuk is offline   Reply With Quote
Old 02-13-2006, 01:03 PM   #6 (permalink)
Member # 65077
Yeah im 100 % its the thermastat, the heater blows just fine, blow really good actually, just blows really cold,
im thinking its stuck open, cause the operating temp is right in the middle of the gauge,
Gonna pick up one after work, maybe flush the RAD fluids
Old 02-13-2006, 03:12 PM   #7 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
heat also only comes out the defrost and the foot area - not out the dash.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 02-13-2006, 04:06 PM   #8 (permalink)
Member # 5832
That depends
It's only *supposed* to come out of the side window defrosters and the top windshield defrosters (aside from the foot vents)
But what can happen is the plastic tubing that goes behind the instrument cluster can split and/or come unattached, and send hot air all throughout behind the dash, escaping out through spaces around the front fresh/cool air vents.
This fakes out a lot of sammy owners into thinking the measly amount of warm air coming through their vents (the wrong ones, or the defrosters where it's supposed to be going)) is the heater's fault, when it isn't, really...
Old 02-14-2006, 05:48 PM   #9 (permalink)
Member # 8687
I'd like to report that I still haven't had to clean my heater since I put that screen in there in the thread Uzi posted. It blows lots of hot air still. Do it while you have it out.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 02-15-2006, 10:16 AM   #10 (permalink)
Member # 48911
come on now, how can you not know where the heater core is? just follow the hot air! then you just follow the coolant hoses from the firewall to find the heater valve.
By the way, be very careful when taking the hoses off of the heater valve. it's a very thin wall hose nipple and can easily be crushed when removing a hose. if it's stuck on there, cut it lengthwise carefully and peel it off. If you bust it, just bypass it for constant heat on or off.
cajunsuzukispider is offline   Reply With Quote
Old 02-15-2006, 04:48 PM   #11 (permalink)
Member # 65839
bad heater core
If your temp gauge is reading in the middle the thermostat is working. The problem is in the heater box. It is full of debree. It's the same problem that all Samurais have in time.
offroad ricer is offline   Reply With Quote
Old 02-15-2006, 09:19 PM   #12 (permalink)
Member # 65077
yeah i cleaned out the heater box, and the heater valve was stuck to the cold setting, Heater works great now:
