Quick Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2006, 09:31 AM   #1 (permalink)
Member # 35396
Quick Question
I an new to the sami thing (got it on monday 2/13/06) i just built a fiberglass enclouser for the back tail gate, i was wondering how much weight it can hold? It has a tire onl the out side, but it tiny, can the door hold a 33-35? the enclouser should only weight 100lbs with the speackers in it (2-6x9's and a 10) ill get pics up later if you guys want to see it....
Thanks
Troy
88 K5 flat findered 10" on 37's SSR, LinXed interior w/14" lcd in the dash...
88.5 Sami YJ'd and 33LTB s
08' GSXR 750 murdered out...
WHOS CRAZY NOW BITCH...
www.GETSQUIRLY.com
1crzy88 is offline   Reply With Quote
Old 02-17-2006, 09:56 AM   #2 (permalink)
Member # 5832
100 LB speaker enclosure?
holy crap.
UZI 9mm is offline   Reply With Quote
Old 02-17-2006, 11:28 AM   #3 (permalink)
Member # 40759
With only about 200lbs to support I'd say you're still within the design specs of the tailgate, go for it!
jamesmross is offline   Reply With Quote
Old 02-17-2006, 12:46 PM   #4 (permalink)
Member # 35396
100 at the most, it will be more like 50 i was just over extimating. the box only weights 15-20lbs.
www.GETSQUIRLY.com
Old 02-17-2006, 12:56 PM   #5 (permalink)
OKIE ZUK's Avatar
Member # 14812
I ran a 35" spare, hi-lift jack and 5 gallons of gas, on the bumper:
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 02-17-2006, 12:58 PM   #6 (permalink)
Bobzooki's Avatar
Member # 9419
Yeah, but it caused your rig to tip over, so how much can you REALLY carry?
2012 Tahoe 24' Fish-N-Fun Tritoon, w/115hp Merc
Tow Rig: The Battlestar Galactica
Bobzooki is offline   Reply With Quote
Old 02-17-2006, 01:03 PM   #7 (permalink)
OKIE ZUK's Avatar
Member # 14812
31" or 32" would be as big as I'd go on the stock tailgate mount. Man this is an old picture from 2000:
Old 02-17-2006, 01:06 PM   #8 (permalink)
OKIE ZUK's Avatar
Member # 14812
Bob, it was the combo of 35" MTR's, 84" wheelbase, steep hill and the a$$ end weight.
Old 02-17-2006, 01:08 PM   #9 (permalink)
OKIE ZUK's Avatar
Member # 14812
If you look real close you can read the gas can " ROLL OVER TESTED ".
Old 02-17-2006, 02:54 PM   #10 (permalink)
Member # 922
I had a 35x12.5 on a steel rim on my stock carrier. It was fine, I was just careful not to let the gate swing away too fast. It even survived a few rounds of bumper car action from my buddies. They couldn't resist a big tire to run into I guess.
FeCamel is offline   Reply With Quote
Old 02-18-2006, 03:56 PM   #11 (permalink)
Member # 30444
i had a 33'' tire and it started tearing the stock tire carrier after about 6 months so i just put a swing out on
1994 EFI Samurai, spoa, yj conversion, 33's, spool,etc.
1993 nissan hardbody, 2" body and 32's; for business
ChristianBenzon1 is offline   Reply With Quote
Old 02-18-2006, 08:25 PM   #12 (permalink)
The_Sarg's Avatar
Member # 35560
Do a custom mod and make it a flipdown tailgate, weight prob solved.
The_Sarg is offline   Reply With Quote
Old 02-20-2006, 11:49 AM   #13 (permalink)
Member # 35396
I think ill probably end up doing a tire swing on the bumper,, so i don't have to worrie. thanks for the responses.
Troy
www.GETSQUIRLY.com
