Toyota P/S problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2006, 02:26 PM   #1 (permalink)
Member # 19643
Toyota P/S problems
Well i got a whole toyota set up pump, box and lines. Get it all home the pump dosen't work because it mounts on the passanger side. . So we put a saginaw pump on and run it to the Toy IFS box. It turns from lock to lock on the jack stands but on the ground it turns left all the way to lock but when turning right it goes about 1/4th.
If i could freaking figure out how do get the power steering going i could be wheeling.
Any ideas of whats happening.
Fat people are harder to kidnap!!
Portrnrzuk is offline   Reply With Quote
Old 02-18-2006, 03:47 PM   #2 (permalink)
Member # 19643
Sorry it has toy axles with a spool in the front. No hysteer ether.
Old 02-18-2006, 10:51 PM   #3 (permalink)
fatkid's Avatar
Member # 4862
show some pics of your steering set up, are you sure its not binding somewhere?
[url]http://www.myspace.com/jerrywsparks[/url]
fatkid is offline   Reply With Quote
Old 02-19-2006, 05:51 AM   #4 (permalink)
NC Zuk's Avatar
Member # 12060
Send a message via Yahoo to NC Zuk
Sounds like your pitman is not mounted in the correct position on the output shaft.
NC Zuk is offline   Reply With Quote
Old 02-19-2006, 07:19 AM   #5 (permalink)
Member # 2752
Is the system bled completely? Turning with a spool is work. My system will bind up with the front arb engaged on pavement if there is any air in the system. Put the front end up on jack stands, turn the wheel lock-to-lock a dozen times or so and have someone watch the reservoir and see if there is any air burping up.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 02-19-2006, 08:06 AM   #6 (permalink)
Member # 19643
I was by myself but i tried to watch to see if it was binding up. I couldn't see anyplace ti was binding up. My steering set up sucks intell i can get hysteer.
Old 02-19-2006, 08:08 AM   #7 (permalink)
Member # 19643
Before I put the pitman arm on I ran the steering from lock to lock, and it took 4 1/2 turns so I turned it back 2 1/4, then put the pitman arm on as straight as I could.
Old 02-19-2006, 08:10 AM   #8 (permalink)
Member # 19643
I think this is the problem I did run it back, and forth a couple times but not a lot. The pump made quit alot of noise also. I'll have to give it a shot tomorrow.
Old 02-19-2006, 08:10 AM   #9 (permalink)
NC Zuk's Avatar
Member # 12060
Ok, just trying to help
Old 02-19-2006, 08:23 AM   #10 (permalink)
Member # 19643
Hope you didn't think i was getting after you? I just posted that to see if I did it right.
Old 02-19-2006, 10:12 AM   #11 (permalink)
Member # 2752
My IFS system primed fairly easily, but not my FJ system. I think it is becasue of the cooler I am running, but I had to spend about three hours alternating between the raised front end method and driving it around.
FYI: In case you didn't know, you need to have the engine OFF when raising the front end and cycling the steering. This uses steering box as the pump and runs the fluid backwards. Works well in getting pesky trapped air out that conventional methods won't get. Good luck.
Old 02-20-2006, 08:22 AM   #12 (permalink)
Member # 19643
I didn't know that thanks.
Another question. Will I be alright using the saginaw pump or would a toyota pump do just as good???
The saginaw take alot of room, and it's harder for the engine to run.
