Is there a shorter Pitman arm I can use? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2006, 01:39 PM   #1 (permalink)
Member # 56802
Is there a shorter pitman are that can be used on the Samurai, then the stock one thats there. I have a yota swap with a high steer and the drag link is hitting the tierod. I don't want to move the steering box nor do I want to more the whells back an inch.
Will anything else work?
-Switch
Switch7 is offline   Reply With Quote
Old 03-29-2006, 02:55 PM   #2 (permalink)
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
pitman arm
If you shorten the arm it will not have the traval you need to steer lock to lock.
1994 Toyota Extra cab, Exo, SAS, 2.28x4.7, 4.88, e-locker/Detroit, 37 Red crawlers, Supercharged 3.4 swap, front and rear Rock Assaults, Air Bumps, marlin 5.15 trans.
2011 KOH Buggy
2012 Jeep Sahara Unlimmited 4" lift on 35s
2005 Dodge 2500HD Cummins 4x4
Edisonsteve is offline   Reply With Quote
Old 03-29-2006, 05:44 PM   #3 (permalink)
Member # 8687
It sounds like a perfect time to add some power steering to your zuke.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 03-29-2006, 06:24 PM   #4 (permalink)
Member # 2752
For stock steering with Yota axles, I use this:
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 03-29-2006, 07:15 PM   #5 (permalink)
Member # 35034
Did you fab this up yourself? If not, where can I buy this?
95 Bronco on bags
kstatecruiser1 is offline   Reply With Quote
Old 03-30-2006, 09:07 AM   #6 (permalink)
OKIE ZUK's Avatar
Member # 14812
Do it your self with two pass. side arms. Just flip one and weld a 1/2" plate gusset inbetween. I run this setup and has worked for three years. With Toys you need a 1" longer pitman arm for the throw, left to right.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 03-30-2006, 12:01 PM   #7 (permalink)
Member # 13806
Do you drive your zuk on the street? If so ,do your self and everyone else and do it right by moving the steering box. This is for safety reasons,otherwise the welded arm will work for ya
RokNRollr is offline   Reply With Quote
Old 03-30-2006, 03:15 PM   #8 (permalink)
OKIE ZUK's Avatar
Member # 14812
Street?:
