Shimmed Power Steering pump? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-11-2006, 08:14 AM   #1 (permalink)
Member # 70954
Has anyone had any luck running a shimmed tracker pump. I don't want to blow the seals out of the box I have. A tracker on 34's and a stock p/s setup just don't cut it.
If I am going to screw up what I have I would rather sell it and rig up something else.
Thanks,
Troy
Stickerpirate is offline   Reply With Quote
Old 04-11-2006, 10:28 AM   #2 (permalink)
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
Sidekick PS pump
I had great luck with it. Stretched spring 1/4" and added a 1/16" washer under it. Worked great till I tapped the sidekick box and added Ram assist. Then I changed to a TC pump.
1994 Toyota Extra cab, Exo, SAS, 2.28x4.7, 4.88, e-locker/Detroit, 37 Red crawlers, Supercharged 3.4 swap, front and rear Rock Assaults, Air Bumps, marlin 5.15 trans.
2011 KOH Buggy
2012 Jeep Sahara Unlimmited 4" lift on 35s
2005 Dodge 2500HD Cummins 4x4
Edisonsteve is offline   Reply With Quote
Old 04-11-2006, 11:01 AM   #3 (permalink)
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
I have heard of people doing this with some good results. I'm gonna change pulley's on my Toy pump myself and see what happens.
My steering is good for locked Toy's on 36's but it could be a little better...lol
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami buggy on 37's
'96 4-door Tracker on 35's
ZookiMelt FB Page:
[url]http://www.facebook.com/profile.php?id=100003375889081[/url]
purevil71 is offline   Reply With Quote
Old 04-11-2006, 11:55 AM   #4 (permalink)
Member # 70954
Thanks for the info.
just one question. "1/16" washer under the spring" did you put it between the spring and the plunger or between the spring and the cap. I really don't think it will make a difference but I am running a a/c pump for oba and it is a real bitch to get to the p/s pump. would like to get it right the first time.
Thanks,
Troy
Old 04-11-2006, 12:01 PM   #5 (permalink)
Member # 70954
I don't know if I would take any advice from a hot seat guy............ Changed my name if you hadden't guessed. Need some more samples for that project rig?
Troy (aka stickerpirate / troyshere)
Old 04-11-2006, 04:34 PM   #6 (permalink)
Member # 17632
Do you have a 6" pulley on the pump and a 4" pulley on the crank? I have been wondering if there was a cheap way to put a 4" pulley on my toy pump.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
