Member # 29930
Location: Winchester VA, USA Its America, why should I have to press 1 for English!!
Stuck transfer case w/Rocky-Road 2low option
This weekends wheeling event was almost over before it started.
A while ago I purchased and installed the modified shift fork to get 2lo. http://www.rocky-road.com/2low.html However, The shifter got stuck and would only go into 2hi or 4hi and would not shift into Neutral or 2lo or 4lo. A couple of guys came to the rescue and helped me pull the shifter out, check the sheet (which was fine) and then move the shift levers manually and put it into 4lo and reassemble. I was able to run the weekend, aside from my other engine problems in 4lo. I can't shift now so I have to figure out why. Anybody else seen this with the Rocky-Road 2Lo option in their shifters? I'll continue to fiddle with it but wonder what more I can do. Suggestions?
Make your kids wear their helmet. Brian P. Gronenthal 1990-2006 http://wearahelmet.org |
Member # 14812
I had the same problem. That's one of the reason I went twin sticks.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc. |
#4 (permalink) | |
Member # 29930
Member # 17632
You shit-canned the detent ball between the rails right? Aside from that, you're just gonna have to take it apart and try to shift it and see what's stopping you.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 14812
Rocky Road's 2 low uses all the balls.
#7 (permalink) | |
Member # 17632
Travis..
