Member # 63322
rear shock mount question
I'm building a Samurai right now with D44's and bought the Spidertrax upper rear shock mount so I could run the long shocks. I have the 32" DT8000 shocks. After reading Brents "shock placement" article and some older threads, I'm having reservations about my shocks being angled in at the top ( like this ^). Is this really a problem(lack of dampening, more body roll, ect.) or am worrying about nothing?
Thanks. |
Member # 6668
The DT8000's may not be stiff enough for this application. When you run the shocks at an angle you need to compensate with stiffer shocks. I run Rancho adjustables. Depending on the load in back (tool box, seat with passengers, empty) you can adjust the level of control. If you just want a standard shock, try the DT5000 models. They are supposed to be stiffer.
Bill Johnston www.izook.com |
Member # 63322
Anyone else have any opinions on this. I did a bunch of searching and am just more confused now. It seems like people are 50/50 on going vertical or on a 45*. I can't decide if I want to keep the Spidertrax mount or use F-250 towers in the rear. I have waggy axles and the rear is in the stock location, so I should be able to mount the F-250 tower vertical without having any shock bind.
If it helps, I don't do much, if any rock climbing. I'm in Alaska and most of the trails are muddy with off camber washouts, ect. |
Member # 63322
Here's a mock up picture of each option I can do. The inverted "V" mount gives me 3" of rod showing, mounting the shock vertical obviously gives me more unless I cut the F-250 mount in half and lower it a bunch.
Inverted "V" ![]() Vertical
Member # 2752
I outboarded my rear shocks to the wheel wells and it made a noticeable improvement in lateral stability. I would caution you to test flex the setup before welding in up though. I had to put 1" spacers on my 87 rear yota axle to keep the tires off of the shock. It was worth the effort though.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, ............. <>< <>< <>< Hey, if this rig is for wheelin', what are all these animal parts doin' in here? |
Member # 44135
Good looking set-up. I ran waggy 44's on my zuk in stock form for years. My opinion is go as close to straight up as possible. I angled mine in 5 degrees and ended up useing shorter rancho 9000's. I had a spoa with wrangler leaves and missing links and after cycling the suspension and measureing went with shorter shocks. I got all the travel the leaves would give me. Mine were mounted on the frontside of the axle inboard of the leaves, but as close as I could get to them with out them hitting. You will be happier if you can get them more verticle. Outboard of the leaves is great, but watch the clearence.
87 Zuk, dana 44's w/5:38 detroits,coils/3 link frt, 3 link rear 37" Krawlers 87 Zuk, SPOA, Lockright/spool, 31" Truxs MT's. shaved and trussed stock axle housings,1.6/w 1.3 head, fuel injected, 4.16 t-case 88.5 Zuk future project pending |
Member # 23056
Mounting the shocks at an angle just reduces their effectiveness, but on a light zuk it isn't all that bad.
At a 45 degress angle, your shock has 70% of it's dampening left. At 70 degrees (or 20 degrees off from straight up) you still have about 94% of your shocks effectiveness. If that's not enough, compensate with adjustable or stiffer shocks.
87 Sami: 1.6 16V, SPOA SR w/ YJs, locked 5.29 toys, 6.5:1 tcase, 35" MTRs, FJ60/Saginaw PS, Warn 8k |
Member # 2752
Ah, someone who does vector addition. Now you're talking to me Another thing I have always considered too is the amount of cycling you get. The same principals apply, but the cycle length of your shocks also gets reduced as you lay them over. I always figured that work=force x distance principal affected the dampening as well as the law of cosines. Not sure if that is correct though.
