Quick Loc ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2006, 10:52 PM   #1 (permalink)
Member # 23134
Quick Loc ???
Anybody running these, i need to know if i should put the little square block back in the center when i re assemble the carrier. it was removed last go around and ran for years that way but i have now sheared the pins in the locker. let me know if you run with it or without it.
Walker S is offline   Reply With Quote Quick reply to this message
Old 06-18-2006, 09:05 AM   #2 (permalink)
Member # 44418
Yes you should put the block back in. Its what holds the cross pins in position.
Do you have one long and two shorter center pins? You should.
IF IT HAS'NT BROKE YET. GIVE IT TIME. IT WILL!!!
jader is offline   Reply With Quote Quick reply to this message
Old 06-18-2006, 01:56 PM   #3 (permalink)
Member # 23134
yeah that is what i have. i'll have to take the block out of another diff because the guy that had it before me left it out last time. Thanks
Old 06-18-2006, 08:27 PM   #4 (permalink)
Member # 48911
that block may be specific to the locker and not just a stock block, make sure. also when I put in mine, things were too tight and I had to go round and round with people to get the truth out of them. when I had put the dif cap back on the carrier it was binding up on the locker. there should be a washer that goes against the block between the block and the side gear of the locker, mine was too tight and I had to sand down the washer till I got enough clearance for it to still have a tad of slack when it got hot.
what you need to do is this: assemble the thing and then push in on one of the locker side gears and rotate it a bit so that the teeth of the two are on one another and not meshed 'into' one another, then make sure that you can push the locker side gear down a little more so that you have about .015 or so gap between the teeth of the two gears, this is for heat expansion so that when hot you still have enough room for it to auto unlock when needed.
cajunsuzukispider is offline   Reply With Quote Quick reply to this message
