while in 4lo clutch slips - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2006, 10:19 PM   #1 (permalink)
Member # 67454
stock sammi just put in a new clutch bout a month ago, went out wheeling a few times with no problem, now when i'm in 4lo it shoots up to 4k and then grabs when i let off it drops to 2k and u can feel it grab, but when i'm in 2wheel i can dump the clutch at 5k and it grabs right away. do i just need to adjust it or do i need to pull it out and use some sand paper cause its glazed?
91sammi is offline   Reply With Quote
Old 07-17-2006, 11:55 PM   #2 (permalink)
Member # 67454
any 1 have any suggestions? i know its a dumb question but any help is really apprecitaed
Old 07-18-2006, 12:11 PM   #3 (permalink)
Member # 11628
Sounds like something is binding. Did you get it reassembled correctly?
how are the bushings on the bell housing for the throwout bearing fork
Did you get the trowout bearing in correctly?
I'd say you need to tear it downagain and run through everything to make sure....
Oh, and make sure the clutch cable is not binding or frayed.
Clean it and lubricate it.
"The road to Enlightenment requires 4-Wheel Drive" - me
Orionn is offline   Reply With Quote
Old 07-18-2006, 01:21 PM   #4 (permalink)
Member # 67454
yes every thing is assembled correctly, it started doing it after a few wheeling trips
Old 07-18-2006, 01:30 PM   #5 (permalink)
Member # 11628
Thats odd.....whos clutch did you use?
Check the cable, unless its new, it may be damaged.
I am afraid that you will be tearing it down again though to inspect it.
Old 07-18-2006, 04:57 PM   #6 (permalink)
Member # 67454
i used the autozone clutch it has a lifetime on it, the cable moves freely
Old 07-19-2006, 04:43 AM   #7 (permalink)
Member # 45927
Did you get your flywheel re surfaced?
92 zuki/buggy 1.6 8v,locked dana 44's f&r with 5:13's, 6:1 t-case with a forrest bucket, 36's
divino92 is offline   Reply With Quote
Old 07-19-2006, 09:16 AM   #8 (permalink)
Member # 67454
yes it was resurfaced
