Free, quick horsepower gain. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-04-2006, 10:01 PM   #1 (permalink)
Member # 50557
I had an idea tonight... Let me explain.
More air flow = more horsepower...
I figured the stock air box had a little bit of intake area, so I decided to increase this.
Take the air cleaner and top off, remove the coldstart vacume unit (in front of the 90 degee tube) and remove the air box with 2 10mm nuts closest to the engine, and 1 bolt in the side closest to the passenger fender...
Now, cut out peices on the side of the box(do NOT cut the bottom!), leaving enough for support and seal... this will in NO way let dirt in the carb, rather the cleaner might clog up 2000 miles early.
Doing this will increase the flow into the air cleaner by 1000%.
On my new samurai, along with replacing the Cat converter, I have gained close to 7 hp... The engine also accelerates 10x's faster.
Sounds like bay, not ass.
Bass Man is offline   Reply With Quote
Old 09-05-2006, 05:53 AM   #2 (permalink)
Member # 11372
Post the dyno results..............
Bill
Subi powered Beetle Buggy
billj is offline   Reply With Quote
Old 09-05-2006, 08:42 AM   #3 (permalink)
john1974's Avatar
Member # 60777
or just cut some holes into the airbox. I have a drop in style KN Airfilter. worked well this way.
[url]http://zuknation.net[/url]
[url]http://4x4auctions.net[/url] Sell for free! No listing fees!
john1974 is offline   Reply With Quote
Old 09-05-2006, 09:25 AM   #4 (permalink)
Member # 18573
Send a message via AIM to shmoesmith
yep, I have cut a hole in the back of the stock airbox (facing the firewall so no water can get in from tire spray etc) and it worked well. You just need to make sure that you do the right calculations on hole size so you dont mess up with the engines intake vs your exhaust size etc. If you do the wrong size on either end you can really mess up your vehicle performance.
I break zuks and my wife fixes them!
shmoesmith is offline   Reply With Quote
Old 09-05-2006, 11:20 AM   #5 (permalink)
dr_claw's Avatar
Member # 11222
I just got a 1.6 intake tube and threw a k+n filter on it.
Originally Posted by 5thgear
Or for $59 you could by 2 vibrators and hold them like handlebars
Teaching Metalwork in Van City
88.5 Suzuki Samurai, Daily driver with locked toy axles.
77 FJ45 cut up with a bunch of misc crap
dr_claw is offline   Reply With Quote
Old 09-05-2006, 01:51 PM   #6 (permalink)
Member # 57173
I just cut out my whole exhaust, which had a clogged cat, and swiss cheese muffler. I put on a home fab 2 inch exhaust with an 18 inch glasspack (cherry bomb??). I can notice a big power difference. almost to the point of not being sure if I want to go through the headache of an engine swap. But for now, with the exhaust I have, how big of a hole should I cut into the airbox. I figured this could be something I could try until I put on the weber and snorkel.
OklaK5Guy is offline   Reply With Quote
Old 09-05-2006, 08:55 PM   #7 (permalink)
Member # 50557
What I did with the holes was cut rectangle sections out of every side of the box, between the verticle rows that "Support" the air box...
As for dyno results? How about 1/4 mile in 20.57 seconds without the cut, and a 17.14 with it cut out. That much of a jump doesn't come from .6 HP.
Old 09-09-2006, 10:28 AM   #8 (permalink)
Member # 71711
3 second gain from openin the air box. Where's the time slip's
88sammi Waggy 44,s 538,s 5to 1 tcase yj front spring,s toy p/up rear spring,s turned backward,s saginaw power steering 36" tsl,s full cage
zukidave is offline   Reply With Quote
Old 09-09-2006, 11:20 AM   #9 (permalink)
zukibrothers's Avatar
Member # 26165
Send a message via Yahoo to zukibrothers
yep we believe you. why am i even wasting my time with this thread?
zukibrothers is offline   Reply With Quote
Old 09-09-2006, 11:36 AM   #10 (permalink)
ShaunO's Avatar
Member # 74314
VW guys have been drilling out their air boxes for years. I've adapted a "Cold Air Intake" from a Japanese car at the wreckers with a K&N knock-off to fit a 1.6. Noticeable increase in performace, and the exhaust sounds a lot "throatier" than stock.
Bubbles: Do you want to see a rocket go, Randy?
Randy: Does it really launch, Bubbles?
Bubbles: Does it really launch? Does the tin man have a sheet metal cock?
ShaunO is offline   Reply With Quote
Old 09-09-2006, 10:30 PM   #11 (permalink)
Member # 50557
I will admit, not all was the air box. I've done a bunch of things sence I got it, but the ones I can think of bettering the 1/4 mile is; the Cherry Bomb, Cat bypass, 2/3's the the exhaust is 2 1/2" piping, about 70 pounds weight reduction. Just to name a few.
I love the sound the most... If I could afford it, I would go with the cold air intake... But I just look for the cheap upgrades.
Old 09-10-2006, 08:52 AM   #12 (permalink)
RockMolester's Avatar
Member # 28602
Putting a snokel and a drop-in K&N filter into my 16v Sidekick made a noticeable difference. On hills where the transmission's torque converter would unlock, it now stays locked. On hills where the transmission used to downshift to 3rd, it now stays in 4th.
But this isn't a free or quick horsepower gain. The snorkel isn't cheap, and you have to cut a fat hole in your fender. But the ram-air effect is no joke and will get you a little bit of a power gain. But not 3 seconds in the 1/4-mile.
2010 Jeep Rubicon: Daily driven rockcrawler
BlueRibbon Coalition: Fight to keep public lands open to the public!
RockMolester is offline   Reply With Quote
