CJ, YJ,or XJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-27-2006, 10:47 AM   #1 (permalink)
Member # 70123
CJ, YJ,or XJ
hey folks, trying to get some opinions here. puting toys under my zuk and im done with the rear with yj springs. Now for the front,i have two sets of springs,a set of cj rears (will they give me the same flex as the yj's or will it be a little stiff). i also have a set of xj's from an 89 cherokee with a 4.0 . They would give me about 8" of lenghtened wheelbase ,but they to are stiff. or should i just round up another set of yj's for the front. i have 0$ in the cj's or the xj's. what do you guys think.
bigzuk is offline   Reply With Quote
Old 09-27-2006, 12:54 PM   #2 (permalink)
OKIE ZUK's Avatar
Member # 14812
YJ's they are cheap.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 09-27-2006, 01:09 PM   #3 (permalink)
dwkremer's Avatar
Member # 72108
I would use yj springs because they are easier to find for CHEAP!!!
They are about the only think that is cheap in this hobby...scratch that..obsession
94 jeep zj 5.2 - dana 60 35 spline rear - dana 44 front - full arbs - 37 MTRs
91 samurai in progress with 2.0, toy trans, dual t-case and ??? axels.
95 in restro progress with 16V and all new
dwkremer is offline   Reply With Quote
Old 09-27-2006, 03:53 PM   #4 (permalink)
Member # 70123
would yall use the yj's even if you already had the cjs,and xj's
Old 09-27-2006, 04:20 PM   #5 (permalink)
Member # 22732
The XJ rear springs I have in my garage are significantly longer and wider than the YJ springs stacked on top of them. What are the negative effects (if any?) from running wider and longer springs in the front than in the rear of your Zuk? Seems to me you'd want it the other way around. However I'm no leaf spring expert
[ 1988 Suzuki Samurai ]
[SIZE="1"]"Dont drive like my brother!" - Click & Clack[/SIZE]
MorganM is offline   Reply With Quote
Old 09-27-2006, 05:53 PM   #6 (permalink)
Member # 17632
I would use yjs up front. They flex nice. I would rather have longer/flexier springs in the rear since, all things being equal, the rear does not flex as well as the front.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 09-30-2006, 05:54 PM   #7 (permalink)
Member # 70123
it seems to me the longer (xj's) are stiffer than the yj's
Old 09-30-2006, 09:44 PM   #8 (permalink)
Member # 2279
Send a message via MSN to ColdNorth
For what it's worth, on an XJ, which weighs at least 80% more than a Sami, the springs are stiff as hell.
...Did some research awhile back on XJ's, and I guess they replace all but the main leaf with the leaves from a Chev S10 pack and they soften up a ton, but part of that is also getting some more lift as the S10's are very arched springs given that the S10's are spring-under and the XJ is SOA.
Just some extra info for you.
I gave away my trucks and bought (and live on) a 27' sailboat. Meh.
ColdNorth is offline   Reply With Quote
Old 10-01-2006, 02:54 AM   #9 (permalink)
Member # 70123
What about cj rears ,do they flex well or are they stiff
