Member # 64778
FJ80 Axles
Anyone running FJ80 axles in their Sami, i have been considering these for a while and was wanting some input. I know some of the benefits are the larger birfs (compared to Toy truck axles), larger ring gear, full floater rear, pass side drop, high pinion fronts, and some have e-lockers f & r. Anyone have any negative comments or words of advice, regarding these axles.
Any pictures (*PAGING HCGALVIN*) of Sami's with FJ80's under them, i'm curious as to how wide it will turn out?? |
#2 (permalink) | |
I don't have a sammy. ![]() EDIT: Oh, ok, I can give some general input.. If you're going to get FJ80 axles, look for an FZJ80 (94-97) - you'll have higher probability of e-lockers and high pinion. The three hangups you might have with these axles is finding them cheap - setting up manual hubs - and figuring out what to do about steering. If you want to keep the steering arm low - it's probably fine. I guess if you do coils you might be able to accomplish that. However, if you want Hi Steer - they're not the same as standard toyota steering arm mounts. In the past, you've been able to take the 4 bolt steering arm off the bottom of the housing and put it on the top, because the top was 4 bolt, as well. The FJ80 uses two big bolts on the top, and 4 bolts on the bottom. OTT can correct this for you, though. You send them your birf housing and they modify it and make you an arm. ![]() Also, the tie rod is behind the axle - which is really neat. As for putting manual hubs on them, IF you use FZJ80 axles, you'll need to modify the front axle shaft a little - you'll have to make the groove the circlip sits in within the hub wider, and then you'll be able to put manual AISIN/Toyota hubs on it. A lot of guys leave the circlip OFF, they say it doesn't do anything anyway -but me and my husband were safe, we widened the groove in the axle. This thread explains the differences, the guys say they don't use the circlip. http://www.pirate4x4.com/forum/showt...hreadid=152005 ![]() As for elockers - get the brain if you can, if not, make your own. ![]() ![]() ![]() ![]()
Member # 64778
yeah, they're 5" wider than the 86-95 Toy truck axles, i'm thinking it will be pretty damn wide.
Now that i think about it...the Waggy 44's are 62.5 wms to wms, correct? That was another route that i was debating. Last edited by Okiyota; 10-10-2006 at 09:43 AM. |
