Home Made Sammi Snorkal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-10-2006, 04:20 PM   #1 (permalink)
fj40highroller's Avatar
Member # 70062
any one have any good ideas and pictures of a do it yourself suzuki samurai snorkal? any help would be great.
fj40highroller is offline   Reply With Quote Quick reply to this message
Old 10-10-2006, 09:15 PM   #2 (permalink)
Member # 63800
One of the guys in my club made one for his Sammy. I think he used PVC with a bunch of angle connectors.
He cut a hole in the fender before the battery and routed the air intake through the hole and up the A-pillar. Not too much to it.
"Iím more flux-core than hard core." -- rustywagoneersdotcom
OffRoad is offline   Reply With Quote Quick reply to this message
Old 10-11-2006, 01:40 AM   #3 (permalink)
Member # 19934
Mine is made of 3" aluminum tubing.
I'll find a pic and post it tomorrow. I'm going to be taking it off and just running a K&N soon.
Snakeman is offline   Reply With Quote Quick reply to this message
Old 10-11-2006, 11:24 PM   #4 (permalink)
kingmick217's Avatar
Member # 44327
Send a message via MSN to kingmick217
I made mine with 2" pvc. The Samurai's air box routing makes it really an easy modification. I used a two chunks of pipe, two 90 degree elbows, and a electric conduit raincap do-hicky thing for the top. I just cut a hole right in front of the battery and routed it along the inside. I had to remove the headlight assembly to get it in there though. Works as a cold air intake as well, not much extra power... but noticable.
Oh you sir. You are definitely fired.
kingmick217 is offline   Reply With Quote Quick reply to this message
Old 10-12-2006, 01:56 AM   #5 (permalink)
Member # 63322
Just an FYI, if you unbolt the headlight/frame brace and move it down an inch or so, you can get 2" ABS by without any issues. Just use a 2" NH(no hub) coupler, and a street 90 and you're good to go.
Niko is offline   Reply With Quote Quick reply to this message
Old 10-12-2006, 10:36 AM   #6 (permalink)
Member # 70062
thanks you guys. i finished it off last night. i'll try to get some pictures posted so you can see it. it looks and works great.
Old 10-12-2006, 10:41 PM   #7 (permalink)
I LOOOVE ROCKS!
RockMolester's Avatar
Member # 28602
Homemade snorkels almost always look lame because there's no good way to "finish it off" with a good-looking ram scoop with hardware store parts. Luckily, ARB can sell you just their scoop for 3.0" or 3.5" OD pipe, the same scoop as they include with their Safari Snorkel kits. This will make your homemade snorkel look much more professional. My housemate is doing exactly that with the snorkel he's building for his Sami. If he ever finishes it, I'll post some pics.
RockMolester is offline   Reply With Quote Quick reply to this message
Old 10-15-2006, 04:30 PM   #8 (permalink)
Peter H's Avatar
Member # 67881
I made mine with some PVC tubes and an old vacuumcleanerhose....
The Ramairhead is also junkyardrecoverystuff glueed together....
Front,
Rear,
TEAM SUPERSAM
Peter H is offline   Reply With Quote Quick reply to this message
Old 10-15-2006, 06:12 PM   #9 (permalink)
zuki_06's Avatar
Member # 62642
i will be doing the same soon and i wanna sink my sammi in a little water. what else should i be worried about if i get in some deep water? ignition? electrical?
88 Sammi - extended shackles - spray bombed interior and exterior
zuki_06 is offline   Reply With Quote Quick reply to this message
Old 10-15-2006, 06:16 PM   #10 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
ignition
vent lines
exhaust
fan/radiator
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 10-15-2006, 06:49 PM   #11 (permalink)
Zukfather's Avatar
Member # 76340
If you got FI definitley worry about your computer. I made a snorkle for a buddies jeep for about $5 plus the cost of a filter. Just get some dryer vent tubing and hook it up to your intake and run it up to your top and stick a filter on it
Zukfather is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 12:35 PM   #12 (permalink)
Peter H's Avatar
Member # 67881
Connect some waterhoses to the vents of your 2 diff's and tranny. Lead the front diff & tranny hose to a high point under the hood. The rear diff can you lead to the rear door.
The ECU should be dry at all times, in to the glovebox is OK.
TEAM SUPERSAM
Old 10-16-2006, 12:58 PM   #13 (permalink)
dwkremer's Avatar
Member # 72108
Originally Posted by Hvy_Chevy
ignition
vent lines
exhaust
fan/radiator
axles, tranny, t-case
Gathering parts 2 buggies: tons, 4Ds, 4WS.
95 Sammy; perfect (restored) Yj's (SPUA) 2.0
dwkremer is offline   Reply With Quote Quick reply to this message
Old 10-19-2006, 12:15 AM   #14 (permalink)
I LOOOVE ROCKS!
Member # 28602
Peter, that is the best home-made snorkel I've ever seen. Great job!
Old 10-19-2006, 01:17 PM   #15 (permalink)
Peter H's Avatar
Member # 67881
THX,
TEAM SUPERSAM
