6:1 tcase gears - stock diffs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-20-2006, 06:28 AM   #1 (permalink)
Member # 81025
hi all, newbie here
i've got myself a set of 33"s and was wondering if a 6:1 gearset would be enough to run them without changing the diff gears? i was going to put a 1.8l engine and box in it but now am thinking about keeping it simple and keeping the stock 1.3.
i'm use the zook to drive the few miles to work everyday but it is built with mud in mind more than street driving..it's tin top spoa on yjs
your thoughts please
slack_d is offline   Reply With Quote
Old 10-20-2006, 06:34 AM   #2 (permalink)
Member # 81025
oh yeah, this is where i can get gears from over here in the uk
http://www.worcester-networks.com/rsmfg/index.shtml
i think it's the same guy who supplies rockroadoutfitters
Old 10-20-2006, 06:57 AM   #3 (permalink)
Sooty Zooki's Avatar
Member # 70031
6:1 is what you want with 33's and stock diffs. It actually says that on the website too if you look here http://www.worcester-networks.com/rsmfg/sj_tbox.htm
Not many people know that Rob used was the original manufacturer for the Calmini Suzuki gears many years ago before they farmed it out somwhere cheaper... Also, worth considering that the lower the R&P gearing the weaker the diff gears get if you do go down that route. You may want to uprate your t-case mounts eventually with a 6:1 as it will place alot of strain on them when crawling...
Sooty Zooki is offline   Reply With Quote
Old 10-20-2006, 07:45 AM   #4 (permalink)
Member # 81025
hey sooty
i got the impression i could run stock diffs but what i was looking for was opinions based on experience more than a vendors point of view or just speculation.
i figured it would be worth asking on this u.s. board because it's everyday stuff across the pond unlike in the uk
Old 10-20-2006, 02:41 PM   #5 (permalink)
Member # 17632
I would surmise that 6:1s with stock axles on 33s is a recipe for broken parts if not driven carefully. My .02 (even though you limeys may not know what 2 cents is )
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 10-20-2006, 02:45 PM   #6 (permalink)
Freaks of Nature
TiMe_1's Avatar
Member # 68458
Ill be runnin 6.4:1 tcase and 32's with stock zuk axles and welded up in the rear. If it breaks, it breaks, then its time for the yota axles.
TiMe_1 is offline   Reply With Quote
Old 10-20-2006, 02:56 PM   #7 (permalink)
Member # 70031
hey sooty
You could also run SJ413 diffs instead of full R&P. Their a bit lower and just as strong as sami ones. Rob is not only a vendor, but a long standing competitor - you can pay him to do your R&P instead if you want, he does'nt care its still money! Still as mentionned above even if you swap diffs, or do R&P, 33's is still big for stock axles and won't help with breakages.
Old 10-21-2006, 04:58 AM   #8 (permalink)
Member # 81025
i've been running 31" tyres with the same aggressive tread pattern for a while without breaking anything, i think i'll get the gears and hope for the best.
the engine swap would be nice but now the zooks to tall to go under the garage door so i'm stuck with it outside now. as it's october the days are going to be. too short, wet and windy from now on to be dicking around on the drive with a big project like engine swaps. balls to it - i'll get the gears and uprate the axles as i go
and travis, i know what 2 cents is - your 2 cents is worth a penny in english money
Old 10-21-2006, 02:46 PM   #9 (permalink)
Member # 65985
I ran a 6:1 case with 33" swampers and stock axle gearing with lockers. The gearing was nice, but I broke front axles frequently.
'10 RZR
'88 1/2 ton zuk..... sold
Elusive1 is offline   Reply With Quote
Old 10-22-2006, 07:29 AM   #10 (permalink)
Member # 23132
I don't know if this helps or not but I am running a 4.9 t-case with 33's and 4:62's and on the high way it is all right and off road is still crawls pretty good with 33's, most of the guys here will complain about breaking stock axles alot , but I am willing to bet alot of them are good at breaking toyotas too some of these guys could break a dana 60 I tell ya
but its all in the name a of a good time. I wheel spin pretty good here and there with my bald tires and I am sure I ll break eventually but.... I ll fix it and break it again.
http://www.zuwharrie.com/gallery/alb...s/12770/kf.bmp
If you need a prototype machinist, or you need something custom machined let me know.
KEITH13 is offline   Reply With Quote
Old 10-22-2006, 11:13 AM   #11 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
I think the 5.14s are the ticket for 33s and 3.73s
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 10-22-2006, 04:47 PM   #12 (permalink)
Member # 81025
i'm gonna stock up on shafts - take it easy on the skinny pedal and see how it goes. if it's too tough on the axles it's gonna have to be yota time next spring
it's a big mud hole as far as wheeling goes over here though so it can't be as hard on the shafts as scrambling up big rocks like you yanks seem to be most of the time. worst part of it here is pulling stuck land rovers out the way so you can pass
