Member # 53581
Best Carb ever...
Gents,
As we all know the standard sammy carb is often crappy. Many people switch to new aftermarket parts like webber and so on. Probebly more people go to the wrecker and find a fitting carb and run that one. Personaly I love the 87 Suzuki Swift 1.3 GS constant vacuum carb Also found on some Toyota models. I just want to know what type of carb you all run on your 1.3 or 1.6 CARBT engine (so not fuel injection) Kind regards Auke
[B]Suzuki Of Road information [/B][URL="http://www.adservices.nl"][B]ADServices[/B][/URL] [B]Even the Dutch can wheel pretty hard......[/B] |
Member # 8687
Do you guys ever go up or down steep hills or get off-camber?
I hate carbs. They suck.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale. |
Member # 70031
I run a Nikki carb on my 1.3 zook. Way better performance than standard Aisin. Better than a weber as they don't flood out so easy when driven up steep stuff but same sort of power gain. Probably the best standard engine performance upgrade you can make. I got a header, cam, skimmed and ported head and the carb gave more extra power than the other mods put together.
Member # 17632
I too have a stocker with no complaints. On steep up/down there are zero issues. Side hills make it load up a bit but I try to avoid side hilling if at all possible.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
#10 (permalink) | |
Member # 70031
They were mainly sold as aftermarket performance replacements, so you can find them as kits for anything from a VW to a Ford. Very popular in Europe - do a search on eBay - you usually see a few for sale... Pitty they are no longer made (Weber won that fight, lol!). |
Member # 70031
Forgot to say, one of the BIG advantages of the Nikki for fitting to the Suzuki is that it so happens that the position of the bolt holes to mount it line-up perfectly with the standard manifold, so no adapter needed.
#12 (permalink) |
Dodge Ram Newbie
Member # 26814
vacuum hoses, Nikki Carb
My sammi has 3miles of hoses, Were you able to connect all of the stock hoses to thr Njkki carb? Maybe this is more simple tha I think and all carbs has a basic vacuum port? Please shed light.
Loren |
#13 (permalink) |
Member # 70031
That's the other good thing about the Nikki - its very simple compared to Aisin. It only needs the vac advance hose from the dizzy, all the ones that come off the manifold simply get blocked off to stop air leak. The coolant pipe that goes into the Aisin is also redundant, so you close off the coolant by bypassing the carb and connecting it back into the engine. This is very similar to Weber install less the adpator - it has manual choke so will need a cable adding. I also modified the standard plennum chamber to fit the carb so I could run a K&N in the standard airbox.
#14 (permalink) |
Dodge Ram Newbie
Member # 26814
Smog Legal
Does the Nikki carb meet smog legal requirements in California or once installed are you doomed to the eternal green sticker/take your chances with the law?
Loren |
#15 (permalink) | |
Member # 70031
#16 (permalink) | |
Member # 17632
Travis..
#18 (permalink) |
Super Willie
Member # 19067
Here are a couple carb swap links, including the Nikki carb...
Nikki carb swap Daihatsu carb swap Pony carb swap And there are tons 'o site on rebuilding and upgrading the Nikki carb, just Google it. .
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
