Member # 81830
cheapest engine swap
I was looking at swaping the 2.0 tracker engine. a company out there makes a kit that it swaps right it and wiring harness is plug and play and all labled. The kit is 1200 and the engine is 700
Member # 9464
Yep, that is as cheap as it gets for an all inclusive 2.0 swap. No one else makes a kit except for Trail Tough. More info:
http://members.cox.net/aftermarket4x4/2liter.html HTH Sean DeVinney
84 Zuk....2.3 Liter Beater, 96 X-90 "looks like a crushed Red Bull can!" “President Obama is the greatest hoax ever perpetrated on the American people,” Clint Eastwood "This is the greatest wealth destruction I have seen by a president [obama]." Jim Cramer |
Member # 81830
http://members.cox.net/aftermarket4x4/comp_proj.html
1600 Engine Adapter Kits This adapter kit uses Trail Tough's original tried and proven 2-stage stud design for adapting the 1.6 engine to the Samurai. It eliminates the need for drilling or welding and makes installation of the transmission easier than ever before! Just bolt it on. Item # SAK-200 Price $149.00 so the 1.6 can be installed for only 150 plus the cost of the engine? |
if you are LQQKing for the adapter plate i have one thats cheaper. yes you have to drill out the top tranny holes ever so slightly about 1/32 on each side (1/16 total) everthing you need for 100.00 plus shipping or less and you get your own stuff local
just let me know |
Member # 5716
It is not quite that simple. I think there are a few other things:
You could always go search at ww.zuwharrie.com. there is a TON of info on engine swaps over there in the technical sections.
Jeff M. Last edited by Spaceman; 11-29-2006 at 08:19 PM. |
Member # 5716
without the vss, i understand that the ECM operates in the closed or limp mode. If that is the case, then that is a pretty substantial penalty according to what I have read, both in terms of overall engine performance and fuel economy.
I would hate for someone to think that they can just ignore that part of the swap.
Jeff M. |
Member # 25964
I don't know if this is true or not, but when I called Trail Tough they said that keeping the 2.0l cool in a Sammi, where sustained rpm's are needed (mud and snow), can be an issue. The fellow suggested a 16v is a better trail engine swap and and 2.0l is a better dd engine. Anyone comment on this?
Let's assume one is swapping the engine into a Sammi engine bay, not a tube buggy. |
