sidekick gear ratios - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-08-2002, 01:36 PM   #1 (permalink)
Member # 7936
Send a message via MSN to mud-magnet
ok, all my searches come up with the 5.13 gears and thats it........ what i want to know is what is the 1st. gear ratio on the kick auto tranny???? 1st on std. tranny???? what is the t-case low??? and t-case high??? thanks
-Mike
94 Sidekick buggy, 16L 8v, auto, dual cases, toyota axles, locked, coils, and 36" Swamper TSL's.
mud-magnet is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 01:49 PM   #2 (permalink)
Shrock's Avatar
Member # 10979
http://www.off-road.com/suzuki/sidekick/sidespec.htm
http://www.off-road.com/suzuki/tracker/trackerspec.htm
This is from a 1992, more at links above.
Manual Transmission
Type Five-speed, all synchromesh
Clutch Dry, single disc, diaphragm spring
Gear ratios
1st 3.65
2nd 1.95
3rd 1.38
4th 1.00
5th 0.86
Reverse 3.67
Transfer gear ratios
Low (4WD) 1.82
High 1.00
Differential ratio 5.12
Automatic Transmission (optional)
Type Three-speed automatic
Torque Converter Lock-up
Gear ratios
1st 2.40
2nd 1.47
3rd 1.00
4th NA
Reverse 2.00
Low (4WD) 1.82
High 1.00
Differential ratio 4.62
Jim Shrake
Armor! - Bumpers, Sliders, Skids
Shrock is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 02:42 PM   #3 (permalink)
Member # 7936
thanks....... t-case isn't as low as i was hopping....... i want to run the kick engine, tranny, t-case, then my stock case, and toy axles with a 95" WB...... it's going in my buggy type rig...... i'll just have to get lower R&P gears....... thanks
-Mike
Old 05-08-2002, 03:04 PM   #4 (permalink)
Member # 5918
Speaking about lower R+P
So everybody knows in swb trackick's
Auto (3spd) =4.62's
5spd manual = 5.13
So what vehicle do the factory 5.38s come out of. This has been something that has recently started bugging me as my lil cousin wants to lift her kick and put 32's on it. I have complete sets of both the 4.62's and 5.13's but I think with her auto it won't be enough (for street/light duty wheeling). Anybody know?
Yeah, I know I should know this but... I don't.
Dave
aka shogunator
Dave: "This wheeling thing is starting to become a problem" -- (updated)-> EX My Wife... : D
dumb is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 03:20 PM   #5 (permalink)
Member # 7936
i think the early 89 trackers tat had the 1.3L's had something like 5.83 or lower.......
Old 05-08-2002, 03:42 PM   #6 (permalink)
Member # 1070
Arrow
Why not run a 4.1 gearset in your zuk t-case, then you could leave the toy R&P alone. Have you priced R&Ps for toys yet?? What ratio is in your toy axles now?? Going to 5.29s can get pricy, depending upon whether or not you can set the gears up yourself.
-Dan
Where is pancakes house?
dangerber is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 03:58 PM   #7 (permalink)
Member # 9033
The low factory gears were actually 5.62 and came on the aforementioned 1.3 carburated early 89 kick. Good luck finding it, though!
UA 2013 participant
Thank you: Nitto Tires, Polyperformance, Nitro Gear and Axle, Bubba Rope.
MudKick is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 05:06 PM   #8 (permalink)
Member # 8111
5:62,5:12,4:62 and there was one more gear set offered but dont recall what it was 4:30 maybee while researching the sidekick gear swap I talked to local suzuki shop and this is what they told me, but the 5:12 manual and the 4:62 auto's were the
most popular and easiest to find.
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-544.1823
Rockrat is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 07:47 PM   #9 (permalink)
Member # 8690
Send a message via AIM to jp008 Send a message via MSN to jp008
I know where there are some of those.....If interested let me know.
Jim Phillips (D.O.R.)
87 Samurai-91 Kick
jp008 is offline   Reply With Quote Quick reply to this message
Old 05-08-2002, 09:25 PM   #10 (permalink)
tZUKnami's Avatar
Member # 7272
I sentyou a PM
87 Zuk,1.6L 16V block w/1.3 8V head,torquer cam,Webber w/modded float bowl vent,RamFlo filter,high flow hogged intake manifold,Holley regulator,6pt DOM cage,SOA,YJ's,DT Prerunners,TT ML's,31" M/TR's,GRS1,Detroit Locker,4.57 RP's,Toy CV Driveshaft,Breeze HighSteer,Bushwacker Flares,Milemarker E9000.
tZUKnami is offline   Reply With Quote Quick reply to this message
Old 05-09-2002, 06:17 AM   #11 (permalink)
Member # 7936
YEAH, i could, but i'd put it in my zuki first....... i need gears for that...... i'm kinda building 2 at once........ never did anything about gears for it yet......planning on running 5.13 R&P and eather an 84 case, or i'll chop the case in hopes of it becomming a 4.16.........
l8r
Old 05-09-2002, 07:36 AM   #12 (permalink)
Bobzooki's Avatar
Member # 9419
If your cousin is gonna be running 32's, you should look at the 5.83 set from Calmini - it's just the ticket to keep the engine running near the optimum range. Standard 'Kick tires are 27" so moving to 32's would be a 18.5% increase in diameter, and moving from the 5.125 to the 5.83 is almost a 14% reduction.
Oh, and to put 32's under a Kick without serious sawzall work, it's gonna take about 6 inches of lift.
The N.A.A.C.P. is a RACIST organization.
Bobzooki is offline   Reply With Quote Quick reply to this message
Old 05-09-2002, 01:51 PM   #13 (permalink)
Member # 5918
Calmini
Bob,
Calmini stuff is a lot more expensive than finding gears at the PnP. I'll just throw the 5.13's in and tell her to deal with it until she can afford the calmini t-case gears.
As for the lift, It's already on order from Calmini (and yes it's 6")
Dave
aka Shogunator
