Tracker Transmission interchangeability question, need help quick! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-17-2007, 01:18 PM   #1 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
hey guys, I've got a line on a new transmission for my samurai. It's got a motor swapped in from a 2003 model 2.5L tracker. It's got an automatic (2wd model) and I'm looking to install another automatic from a 2004 model, now a 4wd model with married transfercase.
I need to know if the 2004, 4x4 tranny will bolt up and talk to the computer of the 2003, 4x2 motor.
Also, I know that 4:1 kits are available for the tracker t-case, who makes them and how much $$?
I've gotta close this deal today to make it happen, so I need quick help! Thanks a bunch.
Mike
Originally Posted by Elvis-n-Texas View Post
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote
Old 01-17-2007, 08:44 PM   #2 (permalink)
Member # 63309
cant help yah there, but sounds like a serious machine, im just downt he road i gotta check that out some time
Strange is offline   Reply With Quote
Old 01-18-2007, 04:56 AM   #3 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Well, I got on the horn with Trail Tough yesterday... VERY knowlegable and VERY helpful. Also had the best prices in town on the gearset for the tracker case by a good margin. I highly recommend doing business with him based on what I've heard thus far.
Apparently in order to make verything bolt up and plug/play I need a 99-00 transmission (smaller output shaft) and any transfercase with the small input shaft and a 26 spline output shaft. Otherwise I can't up lower gears in the case.
So now I'm off to find a 99-00 transmission and transfercase, wish me luck.
Mike
Old 01-18-2007, 07:08 AM   #4 (permalink)
Bobzooki's Avatar
Member # 9419
Good Luck!
You'll positively DROOL over what that 4:1 does to your low range!
2012 Tahoe 24' Fish-N-Fun Tritoon, w/115hp Merc
Tow Rig: The Battlestar Galactica
Bobzooki is offline   Reply With Quote
Old 01-18-2007, 10:20 AM   #5 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
No, actually I'll be pissed. I've already got a low gear kit in my zuk case, this will just keep me even on my low range (4.16:1 now, 4.2:1 then), and increase my high range from 1.8:1 to 1:1. Which means no more geting away with 4.10 gears, gonna have to swap in some 5.29's.
Now when I get the 5.29's setup, and I'm back to being able to use high range, and my low range is another 25% lower, then I'll be happy.
The sole purpose of this transfercase exercise is to shorten my drivetrain, raise my belly, and lengthen my rear driveshaft. Right now my setup is really hard on rear u joints and is totally worthless for use at speed. This was never a problem when I was running leaf springs and mostly on rock trails, but now I've got airshocks and link suspension front and rear, I need to be able to go fast.
The secondary purpose of this exercise is to get the rig fast enough that I can put my passenger in shotgun range of the coyotes on the ranch
