need ideals for mounting winch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-27-2007, 05:11 PM   #1 (permalink)
Member # 67454
scored a 9k pound winch from harbor freight for 249 on sale from 600, and need some pics of how everyones mounted their winches, any help would be great
91sammi is offline   Reply With Quote
Old 02-27-2007, 06:02 PM   #2 (permalink)
Member # 77765
Send a message via AIM to backpack96
i dont have any pics but i had my winch mounted to a plate and ran front and rear reciever hitches in my bumpers.
88.5 samurai, 5.14 Tcase, 12 guage locker and 31's.
01 Ranger 4.0L, 4x4
I'd rather have a bottle in front of me than a frontal lobotomy.
backpack96 is offline   Reply With Quote
Old 02-27-2007, 07:57 PM   #3 (permalink)
Member # 63309
im a little bitch about aproach angle i cut up my grill and mounted my HF winch to the tube bumper back inside the radiator area, about 1/2 inch away from radiator
Strange is offline   Reply With Quote
Old 02-27-2007, 08:36 PM   #4 (permalink)
Member # 51496
I got a nice winch bumper I could hook you up with. You can check it out Sunday!
88.5 Zuk 0n Yotas, 37" IROKs, RRO Coil Kit, 8-valve swap EFI, 4.16:1 t-case, 438's, Just about to get chopped.
For Sale!
[url]http://www.pirate4x4.com/forum/showthread.php?t=557329[/url]
trail rated is offline   Reply With Quote
Old 02-27-2007, 09:04 PM   #5 (permalink)
Marshall-88Zuk's Avatar
Member # 66388
I had a 2x4 welded across the frame rails so I cut it off at the inside of the frame rails and welded in a Universal winch mount (which I think yours probably came with). Did some plating and gussets as well.
My junk:[url]http://www.pirate4x4.com/forum/showthread.php?t=747299[/url]
Marshall-88Zuk is offline   Reply With Quote
Old 02-27-2007, 09:21 PM   #6 (permalink)
ih4x4's Avatar
Member # 11362
Send a message via AIM to ih4x4 Send a message via Yahoo to ih4x4
this is what I did with an old warn winch
82 landcruiser with tbi sbc
ih4x4 is offline   Reply With Quote
Old 02-27-2007, 10:07 PM   #7 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
here is what i did
I have trail toughs missing links and when i saw the new trail gear winch plate for the toy mini i looked at it and said I bet that would work on my zuk! I went over to my buddys shop took out a tape mesure to his toy and found that it might in deed work so i ordered one up
welded in the spacers that came with my missing links to strengthen the frame ( also notice my new toy IFS steering box now i can turn with one finger!)
using some 1/2" steel I made the missing link pad longer
I stuffed a pipe in the the tube crossmember and drilled 2 1/2" holes to put bolts in along with made some 1" spaceres for between the tube and the plate
I also opened up the hole for the cable so i could run a roller fairlead and drilled and tapped new holes for the bolts
looks like it was ment to be on there
now i have a warn M8000 and a new recovery point on my rig
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
