1.3 - carb to EFI - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2007, 03:17 PM   #1 (permalink)
Member # 53518
1.3 - carb to EFI
Finished my buggy a couple of months ago. Other than fouling some plugs, stock carb has worked great. UNTIL NOW. Seems that bouncing over rock while running level caused it to "load up." Couple blips on the pedal would clear it. Now it is burning oil. I.E. blue smoke. I believe the constant rich/lean has burnt a valve. Before I rebuild the head AGAIN, I'm looking at an e.f.i. out of an 89' Suzuki Swift, 1.3 DOHC. Question is, can I bolt this to my 1.3 SOHC??? I know I need ecm, wiring, and e.f.i. components. What else do I need? Elec. fuel pump? What else. Do I need the head off of the DOHC? Will it bolt up? Will the DOHC be any benefit.
Here's some specs on the rig. I'll try to get some pics posted.
87' 1.3 SOHC
stock 5 speed
stock t-case (soon to have 6.5:1 w/ twin stick)
stock sammy axles f/r 5.29:1, quick lok
one link front with 145lb. 14" coils
one link rear with transverse leaf
34x10.50x15 LTB
full hyrdo steer
tube chassis
Almost forgot, 1520lbs.
under $4000.00
Now, let me try and figure out how to post pics...
willyquasar is offline   Reply With Quote
Old 04-09-2007, 03:26 PM   #2 (permalink)
Member # 53518
1st try for pics
1
Old 04-09-2007, 10:18 PM   #3 (permalink)
dr_claw's Avatar
Member # 11222
I like it, kind of divco milk truck
Originally Posted by 5thgear
Or for $59 you could by 2 vibrators and hold them like handlebars
Teaching Metalwork in Van City
88.5 Suzuki Samurai, Daily driver with locked toy axles.
77 FJ45 cut up with a bunch of misc crap
dr_claw is offline   Reply With Quote
Old 04-11-2007, 10:37 AM   #4 (permalink)
Member # 53518
Anyone???
Hate to tackle this totally blind.
Old 04-11-2007, 08:44 PM   #5 (permalink)
dr_claw's Avatar
Member # 11222
get all the wiring and computer. The head will fit on with NO MODS and parts are easier to find that suzuki "truck" stuff. You will need to find a dash from a 88.5 and newer samurai because you need a vss.
You will also need an electric fuel pump from that car or a sidekick. Use an intank pump or buy an aftermarket high pressure pump for efi.
The distributer will also need a hole in your fire wall to clear.
Other than that, you should be just fine.
Old 04-11-2007, 08:45 PM   #6 (permalink)
dr_claw's Avatar
Member # 11222
AND SEARCH !
