changing pinion bearing, any helpful info? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2002, 02:15 AM   #1 (permalink)
Member # 10982
im changing my rear pinion bearing this evening when i get home from work. ive done it before, so i know the basics, but any helpful info would be appreciated.
keep her on all 4's (yeah right)
rockzooki is offline   Reply With Quote
Old 05-30-2002, 05:39 AM   #2 (permalink)
Member # 8111
Check here 4play tech
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-672-9653
Rockrat is offline   Reply With Quote
Old 05-30-2002, 08:01 AM   #3 (permalink)
Member # 5832
Re: changing pinion bearing, any helpful info?
was your previous swap out for a different vehicle (like a Toy)?
or when you did it before, (on a zuk) were there some problems you encountered that you thought "dammit, next time i'm going to see if there's an easier way..." kind of thing?
just curious.
UZI 9mm is offline   Reply With Quote
Old 05-30-2002, 12:48 PM   #4 (permalink)
Member # 8111
replacing only one if so must be a kick 3rd member lack of oil to the front.
Old 05-30-2002, 01:27 PM   #5 (permalink)
Member # 10982
Re: Re: changing pinion bearing, any helpful info?
no its a sammy 3rd, and im changinem both. i figure mud got it.
Old 05-30-2002, 01:54 PM   #6 (permalink)
Member # 8111
Re: Re: Re: changing pinion bearing, any helpful info?
Boggin in reverse with the plug out were ya.
Just fawkin with ya
Old 05-30-2002, 02:43 PM   #7 (permalink)
Member # 10982
Re: Re: Re: Re: changing pinion bearing, any helpful info?
Just fawkin with ya
nah i cut the bottom off my diff for high clearance, the damn theink wont hold oil now, think i should weld a plate in place of the metal i removed?? bwhahahahahahaha(dont take me serious, cause im not)
Old 05-30-2002, 03:53 PM   #8 (permalink)
Member # 8111
Re: Re: Re: Re: Re: changing pinion bearing, any helpful info?
Oh thats all. I turned my rear axle over to get the new suzi high pinion. makes it hard to drain the oil out of it though but it gives better shaft angles. only problem is I cant get the truck go forward it keeps fighting itself fronts pullin forward rear pullin back
put it in reverse and just the oppposite.
Old 05-30-2002, 06:24 PM   #9 (permalink)
Member # 10982
Re: Re: Re: Re: Re: Re: changing pinion bearing, any helpful info?
swap the front, make it a high pinion as well, then youll have 5 reverse gears, but only 1 forward, hell gotta trade something though, right!!!!
