Samurai dead (HELP PLEASE!) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2007, 01:02 PM   #1 (permalink)
Member # 74657
Ok everyone, i have a 1989 samurai with carb and all of california's fav polluition control gems on it!
Up until yesterday my samurai ran like a champ, started up easily!
Yesterday we tried to take the thing on a test drive, she started up with no prolbem, backed it off of a trailer and the thing stalled out. Weired seeing how ive had the thing idle on its own for 20 minutes or so without stalling.
Anyways, i thought there was a fuel delivery problem, pulled off the gas tank and the lines are fine there.
The fuel filter is brand new and looked fine with gas in it.
The steel lines are all new
The fuel pump works and shoots gas every revolution.
The line going from fuel pump to carb is clear
took the fitting that the fuel pump connects to out and the area was dirty, pic:
should that red thing be there?
Also: the car still runs if i pour gas right into the carb, so im thinking that rules out any timing issues..
Let me know zuk experts! i will take any pic that you need to think up some solutions!
simko is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 01:14 PM   #2 (permalink)
catzuk's Avatar
Member # 44135
If it does run while pouring gas down the carb it narrows your search. It does sound like a fuel issue. Does it idle now or nothing at all? Does it try to start? When you put gas down the carb will it fire up and run till that gas is gone?
Id say something is either bad at the pump or carb. Clogged jet perhaps. You said it was squirting fuel when the engine was turning over, but perhaps its not enough to fill the float bowl and keep it running?
87 Zuk, dana 44's w/5:38 detroits,coils/3 link frt, 3 link rear 37" Krawlers
87 Zuk, SPOA, Lockright/spool, 31" Cooper Stt Pro's. shaved and trussed stock axle housings,1.6/w 1.3 head, fuel injected, 4.16 t-case
catzuk is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 01:22 PM   #3 (permalink)
Member # 74657
If we pour gas down the carb it will run till that is gone.
When we crank it tries to start up, we are trying to get to the main jet but it is being a PITA.
WIll replace the fuel pump just incase and it looks like a simple job anyways.
Old 07-02-2007, 03:41 PM   #4 (permalink)
Member # 5829
Ya you got the line off the fuel pump, turn over the engine - does it pump fuel?
People seldom remember what others say - they remember how others make them feel.
0ILBURNER is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 04:14 PM   #5 (permalink)
Member # 74657
yes pumps gas, but like said above, nmight not be enough to fill bowl!
Old 07-02-2007, 04:51 PM   #6 (permalink)
Member # 10487
re: bad gas
I was having some problems getting my LJ80 to run and it would start right up when I poured gas in the carb.
I put a bike gas tank on the roof of the LJ and hooked it to the carb fuel line and it started right up and rine fine. I knew then that there was a pump problem.
Turns out that the rubber fuel line in front and behind the fuel filter was rotten and there was no way for the fuel to get there.
Is your filter plugged? Is the gas good? Water in the tank?
81 LJ 80.....with 800cc of pure power
SJ413 Suzuki Truck DOHC, 31's.......in construction mode.
zukimoo is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 05:31 PM   #7 (permalink)
Member # 74657
new filter, newish gas, tank was drained and refilled (no water). Fuel pump DOES shoot fuel... buddy just cleaned carb, waiting for gaskets to come in for reassembly to finish trouble shooting.
there was an excessive amount of grime/dirt in the float bowl, shot some cleaner through the jets and removed built up kaka, hopefully the problem will be resolved,
Old 07-02-2007, 11:38 PM   #8 (permalink)
ShaunO's Avatar
Member # 74314
I just rebuilt my carb from an '88. I had sank my truck in a 6' deep puddle and flooded the gas tank and a bunch of the bad things happened. Anyways, to drive it home I bypassed the fuel filter and as a result filled the carb with crap.
The whole process took about 3 hours and I had to buy a rebuild kit since the gaskets were broken during disassembly. I blasted the bowl with carb cleaner and removed lots of crap. Most of the crap was on the internal screen, behind the main fuel inlet port.
Go to www.suzukiinfo.com and get the FSM for the Samurai. There are 20 plus pages on the carb rebuild steps.
Bubbles: Do you want to see a rocket go, Randy?
Randy: Does it really launch, Bubbles?
Bubbles: Does it really launch? Does the tin man have a sheet metal cock?
ShaunO is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 10:29 AM   #9 (permalink)
[Memphis]'s Avatar
Member # 49281
ShaunO
Thanks for the link on the carb rebuild... going through it right now (I am Simko's buddy doing all the fukn work)
The carb was dirty as hell, is it worth it to remove it completely off the intake to clean her right out? I only gained access to the bowl (way too many vacuum lines and other gadgets I didn't want to mess with) and removed a fair amount of junk in there.
Driving a 5.3L 4x4 el camino wrapped in tupperware :homer:
[Memphis] is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 11:02 AM   #10 (permalink)
Member # 17632
I would say remove it, it's too much work to button it back up and have it do the same thing. I had a no idle condition on mine a few years back after letting it sit for 5 or 6 mos. I pulled the carb and tore it down enough to flush out all of the passages and re-assembled. It has run like a swiss watch ever since.
Travis..
'15 Ram 2500 4x4 Big C and a 6 speed
2000 TJ on 35's
crashnzuk is online now   Reply With Quote Quick reply to this message
Old 07-03-2007, 08:58 PM   #11 (permalink)
Member # 74657
Ok i scanned a pic of my main gasket, and it is the same gasket in the FSM!
So can anyone tell me if its the Hitachi or AIsin carb? heres my gasket:
http://i2.photobucket.com/albums/y29...h/adara002.jpg
same one in FSM, my samurai si an 1989, I LIVE IN CANADA, so i was thinking it was aisin, but here is the austrailian rebuild kit , note the different gaskets.
