ecotec converisons - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-04-2010, 05:08 AM   #101 (permalink)
Samystar's Avatar
Member # 21385
I did a Ecotec / 700r4 / atlas swap in my ''suzuki'' base buggy. You need a adaptor for the bellhousing. I used the stock power steering pump to drive 2 double end ram for 4 wheel steering and I worked great. For the cooling hoses clearance issu, just bend up the metal hose and a little grindind on the tranny. You will need a custom tork converter. Mine was a corvette 2150 machined to have it bolted to the ecotec flexplate.
a link to the project: http://s31.photobucket.com/albums/c388/OliBuilt/Spider/
[SIZE=4][COLOR=Red]wasazuk...[/COLOR][/SIZE]
Samystar is offline   Reply With Quote Quick reply to this message
Old 02-04-2010, 10:57 PM   #102 (permalink)
rotozuk's Avatar
Member # 8965
Originally Posted by Chet View Post
anything over aorund 120HP is pushing a sammy trans. TCASE can take more but how much? sidekick trans is an almost requirement and a toy tranny is even better. sandrails get away with small trans due to lots of slipping in the sand and super lightweight.
I had a VW 1.8 gas on a Samurai trans and beat the tar out of that thing and the tranny and t-case did not care at all. Eventually my abusive driving blew a ring off a piston and killed the motor.
Anyhow, I think people discount what the Samurai trans is able to handle. I have seen several 4.3 liter swaps that kept the Samurai t-case. I have seen a few turbo and super charged Suzuki motors that were putting out over 120 HP, and also a few VW 1.9 turbo diesels all running through the stock driveline and none of them had problems. (well, diesels will rattle the trans apart over time near an idle.)
If I could easily mate the Ecotec to the Samurai trans, I'd go for that option in a heart beat. Probably upgrade to a hydro clutch though. I hate that cable.
-Wayne
rotozuk is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 10:49 AM   #103 (permalink)
Member # 149176
I'm also going to be building a buggy with the Ecotec small light good power, cheap and plentiful.
The Sky/Solstice Bellhousing GM P/N 89060089 Bolts directly up to the AX-15 internal slave. I have them both in hand.
The bell is 1/4" shorter but I figure I can either make a 1/8" spacer on both side if the splines are not long enough. With 1/8" the alignment pins will still reach.
http://www.hotrod.com/techarticles/e.../photo_04.html
Web wheeling revealed that the 84 Camaro 4cyl clutch Napa P/N RCF4198 is supposed to work 9-1/8" diameter and 10 spline 1-1/8" dia. Summit also sell a centerforce with same dimensions.
To run it I plan on going with the MSD distributor for spark and propane for fuel, should be straight forward and simple.
Level Zero sells intake flanges to make your own intake.
http://www.levelzeromotorsports.com/...ae7b4386e519dd
Only thing I will need to do is build a custom power steering pump bracket but there should be plenty of room where the A/C compressor was.
**Does anyone sell a P/S bracket/pulley for the Ecotec?
Does anyone know of any non one off custom built adapters for an Ecotec to a RWD auto like 904 or something jeep related.
customcreationsllc is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 11:54 AM   #104 (permalink)
Biulder
toykilla5150's Avatar
Member # 65463
If the Sky/solstice bellhousing bolts to an AX15 that also means it will bolt to a turbo or v6 Toyota trans!
YOU CANT FIX STUPID PEOPLE only shoot them.
toykilla5150 is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 01:03 PM   #105 (permalink)
Member # 149176
Correct but the input shaft lengths are different and require more work.
There is a lot of good information here for swapping Asian Bellhousing bolt pattern transmissions.
No sense in repeating it.
http://www.jeeps-offroad.com/f41/eng...housings-4740/
Old 02-05-2010, 06:13 PM   #106 (permalink)
tinbeater's Avatar
Member # 16547
Originally Posted by customcreationsllc View Post
Correct
Great info.
Sure is good seeing a newbie that knows things and not just talking shiat.
tinbeater is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 09:28 AM   #107 (permalink)
Member # 149176
Originally Posted by tinbeater View Post
Great info.
Thanks
I've been around a while, Iím on a bunch of other forums hard to keep on tract of them all. Local jeep clubs, rauschcreek, racedezert, ecotec forum, whatever google brings me too and has good Tech.
I try to only write when I feel it is important I hate all the clutter on the forums.
I donít know much about Suzuki but Iíve been doing a bunch of searching on the Ecotec.
I didnít see the Ecotec Build Book if any of you are interested
http://www.gmtunersource.com/index.p...tec-build-book
I mostly just read on Pirate this site is a little overwhelming there is so much good information here the search button is my best friend. Thatís how I found this thread.
~Justin
Old 03-04-2010, 05:13 PM   #108 (permalink)
KY Mtn Crawler
Shoope1's Avatar
Member # 9865
Send a message via ICQ to Shoope1 Send a message via AIM to Shoope1 Send a message via Yahoo to Shoope1
Good info..
I would also like to know about the 904 tranny adapter if one. Cause I have one built in my garage.
Shoope1 is offline   Reply With Quote Quick reply to this message
Old 03-10-2010, 02:41 PM   #109 (permalink)
Member # 80914
Send a message via MSN to klauss35
Is this thread dead or not??, I really want to see some pictures of this conversion.
Thanks.
klauss35 is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 05:11 AM   #110 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
not that up to speed on these motors, but are they in Saturns? I've seen a bunch around here cheap with either the 1.9s or some V6s (1994 - 2000 range)
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 11:36 PM   #111 (permalink)
Member # 54844
if you guys would like pics and some measurements of the ecotec pm me - a buddy has a supercharged engine sitting in his shop -
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 03-25-2010, 10:16 AM   #112 (permalink)
Member # 149176
GM Ecotec Book
http://members.shaw.ca/warped00/bcjbody/buildbook.html
Old 04-01-2010, 11:30 PM   #113 (permalink)
Member # 151690
Use a transmission out of a Saturn Sky or the Pontiac Solstice. Its the correst bolt pattern for theecotech and almost the same length as the samurai transmission. However the shifter location is a little farther back... The go for 500 to 700 on ebay. You can get a package off ebay for around 3 grand with the ecotech in the 2.0, 2.2 or the 2.4 and you can also get them supercharged or turbocharged.. Its just money and you cant take it with you.
badzook87 is offline   Reply With Quote Quick reply to this message
Old 04-02-2010, 12:10 AM   #114 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
i have one sitting in my wifes car so close to taking it
-jay
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
supazuk94 is offline   Reply With Quote Quick reply to this message
Old 04-02-2010, 06:30 AM   #115 (permalink)
Member # 129728
there is a guy near me that has dozens of these cars, totaled and whole for sale ...
has motors, trannys ... etc out and in various stages of dissassembly ...
if you use the car tranny what do you do for a transfer?
'85bronco,5.13s,60's,spool/detroit,2001cummins505/1032,2006cummins,KFX700-TRX 450r-RZR 900 XP
wv85bronco is offline   Reply With Quote Quick reply to this message
Old 04-06-2010, 05:37 PM   #116 (permalink)
Member # 25306
It has been a while since I have looked at this, Life got in the way but here goes. Just received a solstice tranny today. Here is the tale of the tape.
removable bell housing URL=http://img16.imageshack.us/i/img2933y.jpg/][/URL]
shifter location
87 toy Lexus v8 linked and one tons soon
Ddog87 is offline   Reply With Quote Quick reply to this message
Old 04-06-2010, 09:05 PM   #117 (permalink)
Member # 80914
New Process 231 transfer case, is been used by ICON in their CJ3B replica with an ecotec 2.4 as engine and the Aisin-Warner AX15 five speed as transmission.
http://www.4wheeloffroad.com/feature..._3b/index.html
Old 04-08-2010, 03:13 PM   #118 (permalink)
crashhawk's Avatar
Member # 115887
Hmm, I'm very intrigued.
God hates a coward.
Nolite esse canis praecisae
crashhawk is offline   Reply With Quote Quick reply to this message
Old 04-08-2010, 08:43 PM   #119 (permalink)
lenross1's Avatar
Member # 105385
will the bellhousing work with an aisin tranny? has anyone done this? I think that would be the setup so you can run yota tcase, maybe even dual marlins if it not to long...
87 samurai 3sp auto/1.8 kick tcase/4:1 dana300, yota axles, 4 link rear, 39" krawlers.. reds
build thread:
97 FZJ80 supersets,chromoly rear axles,4.88s , 345 KM2s
lenross1 is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 08:36 AM   #120 (permalink)
Member # 154207
ive been salivating over that icon since that came out. i sure would like to know how they bolted all that up.
rile is offline   Reply With Quote Quick reply to this message
Old 04-11-2010, 08:02 PM   #121 (permalink)
Member # 25306
Solstice bell housing on Toyota tranny
Toy on the right Eco on left
3/4 on an inch taller
Old 04-12-2010, 09:40 AM   #122 (permalink)
lenross1's Avatar
Member # 105385
so do you need a longer input shaft to make it work?
Ddog87, the solstice bellhousing did directly bolt up to aisin tranny. any mods needed to bolt it together? i noticed in your sig that you have a 87 yota. are you having any motor fitment issues? do you have full body or are you tubed out? I am curious if you have enough space, cause if you dont then the ecotec motor definitely wont fit in a samurai.
build thread:
Old 04-12-2010, 09:53 AM   #123 (permalink)
Member # 25306
This is just ONE of many projects I have an addiction. No mods to make the bell housing bolt on. The solstice input shaft is alot longer I'm looking into this problem next.
Old 04-12-2010, 09:57 AM   #124 (permalink)
Biulder
Member # 65463
3/4" spacer between the bell and trans. Problem solved.... well kinda
Whoops i was thinking yota bell on solstice trans
Old 04-12-2010, 12:03 PM   #125 (permalink)
Member # 25306
The solstice bell is the deeper one. You would need to make it 3/4 shallower. Maybe shave each side of the bell housing if there is enough material
